First post, by wbahnassi
I recently got my hands on an IBM ProPrinter II. It's a dot-matrix parallel printer, but has the flexibility of taking both continuous papers as well as individual papers without holes on the side.
The thing was abandoned for quite a while, so it's dusty, but otherwise has no major damages. I turned it with the test routine, and it printed the page you see in the attachment.
The two issues I noticed are the missing thin lines and the fading out of the left side of printing.
I tried repeating the test several times and the ink started to come back stronger, but those empty streaks are still there. Would this be a symptom of the ink ribbon or the printing head?
I have no idea how to maintain those old printers (nor new ones for that matter), so I don't know what would be a good procedure to fix those issues.
Looking for suggestions
Turbo XT 12MHz, 8-bit VGA, Dual 360K drives
Intel 386 DX-33, Speedstar 24X, SB 1.5, 1x CD
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, Voodoo3, RTX2080Ti
Reply 1 of 2, by LeFlash
No reply? Ok, let me try!
I can only speak about the nec pinwriter, but most printers of that era are similar.
It can be that the print head is defect or the needles are stuck. Try to remote the head, normally it's held by screws or clips and clean the front with isopropanol alcohol.
Maybe the flex cable is kinked or broke, or the driver ic. But try that first.
And some contact cleaner for the connector of the head!
Reply 2 of 2, by wbahnassi
Thanks for the hints. After operating for a few times, the ribbon cable for the printing head developed a wonderful tear across it. Not sure if it was already torn a little and it got worse through movement.
Do you think it's feasible to solder the lines across the tear? I fear with all the movement the solder will crack eventually.
