First post, by DustyShinigami
- l33t
I've decided I want to make a dual-boot with Windows 95 and 98. I know many would ask the question 'why'?, but in truth, 95 was the very first version of Windows we had, so there's the nostalgia, but it's also to have plenty of flexibility and customisation at getting games to run properly. For some weird reason, the very first CD-ROM game we ever had with our first 95 PC - Dr. Drago's Madcap Chase - just was not installing to Windows 98. I have no idea why because on my test build, it did work without a hitch. When I came to install it on my current setup, it just stops responding when you try to run the installer. I tried uninstalling some drivers and software - tried a range of things - and it just wouldn't work. It's a WinG game and I've read some of those can be picky, even under Windows 98. I tried installing the drivers for it, but it still wouldn't work.
So, I figured, for some awkward games, I would have Windows 95 and 98 on the system. Just in case. However, I've never created a dual-boot with old versions of Windows and hardware before and I'm a little confused. Do you have to create an Extended Partition in FDISK in order to partition the C drive? And if so, how do you format it? Initially, I had a partition set up with about 10GB and installed Windows 95 to that. It installed and booted fine. However, I'm a bit unsure how I would get Windows 98 on the second partition, using the rest of the unallocated drive space. Creating an Extended drive worked, but I'm lost on how that would be formatted and how you would select it to install Windows 98 to. I booted the 95 boot disk using my Gotek flashfloppy drive, but typing format c: looks to format the whole drive. And if I just create an Extended partition and boot the Windows 98 installer, wouldn't that just install to the first partition and overwrite the 95 install?
Thanks
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
