First post, by STX
- Member
I build PCs using hardware from 1998-2005, but I choose newer power supplies for the systems that I really care about. My favorite tool, the OuterVision eXtreme Power Supply Calculator, shut down this year, and I miss its ability to show 12V, 5V and 3.3V current loads in Expert mode. Very old versions on Archive.org still work, but they do not show 12V, 5V and 3.3V current loads separately, and newer versions can't access the nonexistent server-side data for making calculations. The best power supply calculator that I have found is takaman's Power Supply Calculator. Do you know of other power supply calculators for 1998-2005 hardware that show separate 12V, 5V and 3.3V current loads? Thanks!
TL;DR Check this out: takaman's Power Supply Calculator
Are there other PSU calculators for 1998-2005 hardware that show 12V, 5V and 3.3V current loads?
