First post, by Gavrilo
Hello fellas,
creating new topic, hope there isn't something already on Vogons, you know why.
I got old WD Caviar 2850, plugged it to my 486 system and found out there was some Linux. So I booted it with MS-DOS 6.22 diskette, used fdisk and removed the first primary partition and also the second non-dos partition. Now I have only 504MB of space. What can I do to have full capacity?
Thanks.
Reply 1 of 8, by konc
Were you able to see the full capacity before deleting the partitions? I'm asking because the number is suspiciously the same as the classic BIOS limit.
Reply 2 of 8, by Gavrilo
Yes, the fdisk showed lot more megabytes. It crossed my mind also, but then I used Windows 98 boot diskette and the result was the same.
Reply 3 of 8, by Kouwes
I just had the same with a 540MB Seagate HDD. It has slightly more than 1.024 cylinders but the BIOS of my 486 board can’t handle that so I ended up with about 520MB.
Reply 4 of 8, by chinny22
What does BIOS detect the drive as?
Reply 5 of 8, by Grzyb
When detecting the drive in BIOS - is there "LBA" option?
If there is - just use it.
If not, then the BIOS is limited to about 500 MB.
You can override BIOS limits with software like Ontrack Disk Manager.
In 2003, I voted in favour of joining the European Union. However, due to recent developments - especially the restrictions on cash usage - I'm hereby withdrawing my support. DOWN WITH THE EU!
Reply 6 of 8, by Gavrilo
Grzyb thanks a lot. In the System Configuration table after the POST screen there was 853MB whether the option was set in BIOS for NORMAL or LBA for this HDD. But I set the option to LBA, used MS-DOS boot diskette and I fdisked the drive again. Now I have 813MB. I sys the drive but after computer restarts, there is no Loading MS-DOS. There are som Linux Grub leftovers. How can I get rid of 'em?
Reply 7 of 8, by Disruptor
boot from dos diskette again and type
fdisk /mbr
Reply 8 of 8, by Gavrilo
I was searching the internet like crazy and there are some pretty complicated stuff, but you gave here this genius and simple solution. Thanks a lot 😀. The fdisk /mbr command saved the day.
