First post, by NeoG_
I was checking the disk performance of my SS7 AT rig (Motherboard ACORP 5ALI61, M1542/M1543 chipset) and noticed the disk speeds are limited to around 10,500KB/s with high CPU usage. I tried a bunch of things but couldn't seem to increase the performance at all.
- The SD-to-IDE and Seagate drive both support UDMA (33 and 66 respectively)
- The SD adapter does about 25MB/s and the HDD does around 35MB/s max when connected to a 440BX board
- DMA is enabled and stays checked in device manager and in SiSoft Sandra
- BIOS detects the transfer mode as UDMA Mode 2 with UMDA set to Auto
- Tried Microsoft, ALI M1543 1.00 and 3.54 bus master IDE drivers, all perform the same
- Tried Microsoft, ALI M1542 GART 1.20 and 1.65e drivers, all perform the same
- Fresh install of windows 98 with all cards removed and just enough drivers to enable DMA, still capped
- With only a single IDE device on primary master or secondary master, speed cap remains
Is this just how fast the IDE controller is on this chipset? Can anyone with an ALADDiNV board confirm what the IDE speed maxes out at?
