First post, by luRaichu
It's all in the title... I installed OS/2 Warp 3 from floppies onto my Compaq Contura 3/25c and there isn't an option to drive the LCD in 256 colors.
DOS games display in 256 colors once set to fullscreen.
I tried the generic SVGA driver from IBM, but had no luck with that one either.
Which display driver do I need?
Reply 3 of 16, by douglar
Hmmm. It's probably built into the chip labeled "128959-003 ©1992 COMPAQ "
Can you boot off a floppy and run HWinfo16?
Reply 5 of 16, by douglar
Whoa! OK, so it's in the AVGA / Qvision family
Good news is that it might have some 2d acceleration. Bad news is that finding drivers is hard.
You can find the softpaq for Qvision OS/2 drivers here: https://www.os2site.com/sw/drivers/video/misc/index.html
Reply 6 of 16, by PC Hoarder Patrol
These are the latest QVision / AVGA family drivers for OS/2 2.X & 3.0 I have listed (v2.39)...they should support up to 1280x1024 at 256 colors / 64K color modes, depending on which chip is used
The attachment SP2747.exe is no longer available
The attachment SP2747.txt is no longer available
Reply 7 of 16, by luRaichu
PC Hoarder Patrol wrote on 2025-11-10, 06:28:
I installed these and they broke my OS/2 installation... luckily I made a CF card image
Reply 8 of 16, by douglar
luRaichu wrote on 2025-11-10, 16:21:
Good luck with your adventure. Takes me back to 1992 when I was trying to make my speedstar 24x work under OS/2 2.0. So many crashes that required booting from floppy to fix.
I remember booting from a floppy to edit the config.sys to roll back changes, but that was a long time ago.
Reply 9 of 16, by luRaichu
SP2747 will decompress itself onto three floppies.
When the INSTALL program is run from the first floppy, it will try and fail to perform a hardware check on this machine:
The attachment PA190133.JPG is no longer available
Then it will proceed to only install one file which will break OS/2.
EDIT: This isn't true. it'll install multiple things, but only from the first floppy, and it still breaks OS/2.
I did try installing SP0406 / qvision.zip from the os2site misc. video drivers page, but it also breaks OS/2. I don't think it's Warp compatible anyways.
The attachment PA180132.JPG is no longer available
If OS/2 can't show me 256 colors on this machine I'll have to downgrade to Windows 3.1
Reply 10 of 16, by PC Hoarder Patrol
luRaichu wrote on 2025-11-11, 01:10:
SP2747 will decompress itself onto three floppies. When the INSTALL program is run from the first floppy, it will try and fail t […]
Strange one, as the model is shown on the driver support list...
The attachment QVision OS2 Display Drivers - Systems Supported.png is no longer available
Suppose it might be worth trying some of the previous driver versions...
sp2747 (v2.39)
sp1395 (v2.30 Rev. A) - https://ftp.zx.net.nz/pub/archive/ftp.hp.com/ … 1500/sp1395.exe
sp1078 (v2.21) - https://ftp.zx.net.nz/pub/archive/ftp.hp.com/ … 1500/sp1078.zip
sp0964 (v2.20) - https://ftp.zx.net.nz/pub/archive/ftp.hp.com/ … 1000/sp0964.zip
Anything earlier than those don't support Warp.
Few other thoughts...
...did you apply the latest Warp FixPak diskset to the base OS install
...there's also an SVGA BIOS extension TSR app available here - https://ftp.zx.net.nz/pub/archive/ftp.hp.com/ … 2000/sp1728.exe
Reply 11 of 16, by luRaichu
PC Hoarder Patrol wrote on 2025-11-11, 17:03:
No.
I tried SP1078 last night but it told me that I don't have a QVision controller.
The attachment PA190134.JPG is no longer available
SP1395 gave the same results as SP2747.
Reply 12 of 16, by luRaichu
Installed FixPak 26.
SP0964 throws the same error as SP1078
SP2747 and SP1395 still break OS/2
Reply 14 of 16, by luRaichu
I've ran some tests with several DOS / QBASIC programs, and I really don't think the laptop hardware supports 640 x 480 @ 256 colors.
It appears to adhere to IBM's original VGA standard, which only supports 256 colors in 320 x 200.
https://en.wikipedia.org/wiki/Video_Graphics_ … ay#Capabilities
Reply 15 of 16, by theelf
luRaichu wrote on 2025-11-13, 23:32:
Maybe is like Contura Aero 4/25, that have 512kb vram, but only 256kb are accessible because SPC8108
The other 256k, Compaq says, is for the “pop-up thing when coming out of stand-by” and looks like LCD controller cant touch it.
Reply 16 of 16, by luRaichu
You can see from the board pics that this laptop does have 512k of video memory. HWiNFO reports 512k while SciTech Display Doctor on Windows 3.1 says 256k (and that this video chip is not supported)
