First post, by lilylarceny
I have been playing late era xp 3d games, and I noticed the longer I play, the game will gradually have worse performance, usually in the form of draw distance. I ran hwinfo and it seems my 980ti is being thermal throttled, reaching 85c (throttle happens at 83c). the gpu fan is spinning up like it should, showing 1000rpm idle, and 2200rpm at max temps. is there any way to adjust the fan profile on winxp or bring the temps down in any other way? i think most of the software for this card is for later versions of windows.
my cpu is on an aio liquid cooler and never goes above 45c (30c at idle)
the system has 3 120mm case fans in addition to the cpu radiator fans
specs
Winxp sp3 integral
Gigabyte G1.Sniper z97
Intel i7 4790k 4.4ghz
16gb ddr3
evga 980ti reference
creative x-fi titanium
Reply 1 of 4, by Joseph_Joestar
lilylarceny wrote on 2025-11-10, 04:07:
Try older versions of MSI Afterburner. You might be able to adjust the fan curve manually from there.
By the way, a GTX 980 Ti hitting thermal limits while running WinXP titles isn't exactly normal. Are you playing without V-Sync by any chance? That's a bad idea, since physics in many WinXP era games break above 60 FPS. Alternatively, the thermal paste on that GPU might need replacing.
My retro stuff
Reply 2 of 4, by myne
Whens the last time the goo was replaced?
10 years ago in the factory?
I built:
Reply 3 of 4, by AlexZ
You also have founders edition, those run a bit hotter. Replace thermal paste, use v-sync and set up fan profile in MSI afterburner.
Unfortunately GTX 580 is the last GPU supported by NiBiTor where you can set fan profile in BIOS.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 MT-40@2.4Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 965,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,16GB,GeForce GTX 980 Ti
Reply 4 of 4, by lilylarceny
Joseph_Joestar wrote on 2025-11-10, 07:16:
V-Sync was the ticket, brought it down to ~70c
the paste is no more than a year old.
