First post, by andreab88
Hello VOGONS community!
I'm currently restoring a Canon NoteJet BN700 (also known as NoteJet IIIcx ) and I'm having trouble finding the original printer and scanner drivers with utilities.
The situation is a bit unusual: I have the original hard disk with the working software installation, but when I try to copy the driver files to a fresh Windows 95 installation, they don't work properly. The printer utility seems to have registry dependencies or other system integrations that don't transfer with just the files.
What I'm looking for specifically:
- Original Canon driver installation files (ideally the floppy disk images or the printbn700.zip package)
- Canon Utility Disk contents
- Print utility software that came with the laptop
I've already performed a lot of research (looking in Archive.org, GitHub and so on), but I didn't found what I really need.
Has anyone here preserved these drivers or dumped the original installation floppies? I'd be happy to properly archive and share whatever I find to help others in the same situation.
Thanks in advance for any help!
Reply 1 of 3, by andreab88
Just an update.
I finally managed to restore the Canon utilities on my NoteJet and decided to create a GitHub repository with all the necessary files (utilities dump, drivers, and required system components).
You can find it here: https://github.com/andreabusi/canon-notejet-bn700
Hopefully this helps!
Reply 2 of 3, by sangokushi
Nice found! Does the built-in printer still work?
Reply 3 of 3, by andreab88
sangokushi wrote on 2025-11-16, 22:25:
Yes it works properly! I will post some photos in the next days 😉
