I managed to do it but in a similar TV model LG 42LF2510
You need to remove the CEA extension from the EDID data of the HDMI connector and write a new one to the monitor, e.g. using PowerStrip 3.83 (full) and ATI 9550 AGP graphics card - this really works ๐๐ https://www.elektroda.pl/rtvforum/viewtopic.p โฆ 761860#21761860
The attachment no_CEA.png is no longer available
The attachment RS232.png is no longer available
The attachment HDMI2.jpg is no longer available
The attachment HDMI2.png is no longer available
Now I can choose any scaling mode in NVIDIA driver settings and the interlace mode does not turn on - it still works in progressive mode ๐๐
PowerStrip can also program EDID using a PCIe NVIDIA 6200 card, but:
EDID EEPROM cannot be write-protected mode - I test on LG 42LF2510. It didn't work with the 22MT44DP model from the first post because it has EEPROM in write-protected mode !!!
the system must be WinXP or probably newer
PowerStrip must be in the full version - newer than 3.63 - I tested with 3.85. Old version 3.63 is the last version that works on NT 4.0 but it cannot program EDID, newer versions do not work on NT 4.0
NVIDIA card driver cannot be installed or WinXP needs to be restarted to VGA mode
in WinXP on Haswell, only 185.85 drivers are installed and with EDID CEA there is the same problem as in Win NT 4.0 - no scaling and interlaced mode. After changing EDID to no_CEA, everything works OK and scaling is available
The attachment 6200_EDID_OK.png is no longer available
The attachment CEA_HDMI.png is no longer available
The attachment CEA_no_scaling.png is no longer available
The attachment no_CEA_DVI.png is no longer available
The attachment no_CEA_scalling.png is no longer available
P.S. EDID can also be changed in Linux, e.g. Debian 9, using i2c-tools:
I managed to achieve the same on LG 22MT44DP (with write-protected EDID) using the DIGITUS EDID HDMI emulator DA-70466 ๐
The attachment DA-70466.png is no longer available
How I did it:
you need another TV/Monitor in which you can write-enabled EDID and use Linux to write EDID with CEA extension removed
since the NVIDIA 6200 graphics card has a DVI output, we need a HDMI-DVI adapter:
The attachment HDMI-DVI.png is no longer available
connect DIGITUS, set it to clone mode and copy EDID
now just connect the target LG:
NVIDIA 6200 DVI > HDMI-DVI adapter > DIGITUS > HDMI-HDMI cable > LG 22MT44DP
Everything works as it should - all scaling modes works in progressive mode - no interlaced, no blurry fonts and fullscreen CMD apps works in properly scaling mode e.g CCS64 commad line emulator set to 400x300 resolution ๐
The video signal flows through DIGITUS from the graphics card to the monitor, but the EDID is from DIGITUS instead of the monitor.
The attachment DIGITUS_NO_CEA1.png is no longer available
The attachment DIGITUS_NO_CEA2.png is no longer available
