First post, by fiasn
got a replacement battery for my Latitude C610 off ebay (i know...) and have had a strange issue with it. it works absolutely great with the laptop and my C640, and also seems to provide the advertised runtime/capacity (66WHr) but it only charges 4% and then stops until the battery is removed and then put back in. it will then charge another 4ish percent before once again stopping. the charging LED stays solid green, but HWinfo reports a 0.000W charge rate. i have tried multiple 70w and 90w adapters with the same result. really frustrated as the battery otherwise works great. any ideas?
Dimension 4100, Pentium III-EB 1GHz, i815e, 512mb PC133 CL3, GeForce2 Pro 64MB, SBLive! 5.1, VIA VT6212L USB2.0
Latitude C610, Pentium III-M 1.2GHz (Tualatin), i830MP, 768MB PC133 CL2, Mobility Radeon 7000 16MB (128bit)
PMG4 Dual 866MHz, FX5200, 2GB DDR
Reply 1 of 1, by fiasn
Bump, as the problem is still occurring
