First post, by popcalent
Hi, all.
I made the floppy switch board from Techtangents featured in this video (https://www.youtube.com/watch?v=8tzuIGf6x1Y). I downloaded his gerber files. I'm trying to get a 1.44MB, a 1.2MB, and a 360Kb unit to work on my computer.
The board between two of the three units. One possible configuration is to have A: unit as normal (after the twist), and the board (before the twist) switches between B: and D:. The other possible configuration is to have the board after the twist and switch between A: and D:, keeping B: before the twist. I went with the former.
I tried to do 1.44MB as A:, 1.2MB as B: and 360kb as D:, and after that, all other five combinations, and no matter what I do, D: never works. MSDOS prompts me to insert a disk (toggle the switch), I do, then drive D: tries to read the floppy, and it fails. All three drives work perfectly fine as A: or B:, but none of them works as D:
I'm adding these lines to CONFIG.SYS (depending on what drive is D:):
If it's the 1.44MB: DEVICE=C:\DOS\DRIVER.SYS /D:1 /F:7
If it's the 1.2MB: DEVICE=C:\DOS\DRIVER.SYS /D:1 /F:1
If it's the 360Kb: DEVICE=C:\DOS\DRIVER.SYS /D:1 /F:0
and drive D: never works. The connections are correct, and the placement of the twists are also correct (I tried to change them just for sanity check, and when they're misplaced, the drive doesn't even turn on its light). So, at this point I don't know what else to do. Has anyone else tried this and encountered the same problem? I'm hopping I'm doing something stupid and someone will be like "Oh! Yeah! You forgot to switch the board from evil to good" and then it'll work. I've spent a few hours already...
