First post, by freekymachine
- Newbie
Heyo.
I got from a friend a non-working X4000 here.
The Mainboard is an Tyan s2603 - WTX PSU like iWill DX400 [ also in Fujitsu Siemens Celsius ] / DP400 and the MSI 6508 [IBM Intellistation ]
orig PSU is not existant - i have build an Adapter for WTX - also thanks to this community here 😀
Still have it - and it still serves and works well^^
Now - i tried to boot up the X4000 - but nothing happens - No Fan-Spin, no hexcode, no beep - only colorcode possibly Red-Red-Yellow-Yellow - depends how you hold the Panel.
Most points either to "replace system Board" - Or Ram not found -> also possibly "change Memriser"
While cleaning the Board and Memriser i saw some white/crusted stuff on the backside on 4,5 Pins of the Memriser-Port - doesnt look serios, nothing burned - one wipe with isopopanyl and it was gone (should have taken picture)
And on the the Memriser i saw it was soldered on - 5x capacitors were exchanged.
Looks ok done - but still ?! - are those even the right ones ? - 2x are even too small from radius - And which ones were original there ?
The picture from retroweb is ofc high-quality - from above...
https://theretroweb.com/motherboards/s/tyan-s2603
Someone accidently has this system/Memriser and could tell me what should be originally there ?
Thanks & greetings
