First post, by freekymachine
- Newbie
Hey,
I got currently a lot of Xeon 603 on my hands - no idea how that happened 😀
Got an X4000 from a friend - sadly not working no idea yet - and he also got a Compaq W8000.
Both PSU are non-existant - the X4000 is a WTX like Tyan 2603/MSI 6508/iWill DP400 & DX400-SN
The Compaq W8000 says "WTX" aswell - but its totally different.
I did built a temporary Adapter - but machine does absolout nothing - also nothing smoked or exploded.
Here are the 2x connectors it has ;
https://pinoutguide.com/Power/wtxmain_pinout.shtml - a 24 Pin
https://pinoutguide.com/Power/wtxadd_pinout.shtml - a 22 Pin
While the 24-Pin is straight forward normal to build an has even 2x positive ratings..
The 22-Pin is something completly else - some Pins even marked with ??? - nor seemed to have tried or rated anyone it.
The Pin-Out Diagram is not marked from where to view - but only sense it makes if it is seen from the backside.
Pin-1 also marked on the Mainboard - and if you start measrung some groundpins - all other options make no sense.
Question1 is ofc - "am i really right - or did i mess up ?"
Question2 - Did anyone ever tried to adapt the W8000 PSU ?
More i think of it - it might not even be possible - reminds me of the Compaq SP750 and AP550 where no solutions are known either. Maybe the W8000 ques itself in there aswell.
A very very heavy 3.3V PSU / Some own Indicators/Sensors/CLock-Gen/Fan-Control in there ?! Might not even react if all of them are in place ?!
