First post, by DustyShinigami
So it's been brought to my attention that I shouldn't be modifying the autoexec.bat and config.sys files...? Have I been doing things wrong this whole time...? Apparently I should be using a custom PIF file and running commands via DOSSTART?
Could someone shed a bit more light on this as I'm a bit confused as to why I shouldn't modify autoexec and config myself in Windows? I thought this was the right approach, but apparently not. Also, I'm not too familiar with DOSSTART. I'm not even sure I have this file in the root of my C drive.
I'm still not 100% clear on how to set up a custom boot menu, either. Only that it can be done via one of these files, but I forget which.
Thanks
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
Reply 1 of 16, by Errius
This is a huge headache. I'll post a screencap of the notes I made for my own reference.
Is this too much voodoo?
Reply 2 of 16, by DustyShinigami
Errius wrote on 2025-11-21, 14:35:
'A huge headache'...? As in, it's too much of a pain to explain it to me...? Or it's just too much of a pain explaining it in general...? ^^;
But thanks for sharing those notes. So, my takeaway from that then, is that using DOSSTART to add commands is faster...? And that I should boot with a new configuration and install the drivers in pure DOS...? Exit, and then copy the contents created in autoexec and config and paste them into Exit to DOS.PIF...? And then always use the Exit to DOS.PIF...? Which is the same as if you were to click on Start>Shutdown>Exit into MS-DOS Mode?
OS: Windows 98 SE
Reply 3 of 16, by asdf53
DustyShinigami wrote on 2025-11-21, 13:24:
So it's been brought to my attention that I shouldn't be modifying the autoexec.bat and config.sys files...? Have I been doing t […]
Thanks
You can absolutely modify config.sys and autoexec.bat, that was the norm back then. In fact, there are cases where this is needed, for example loading a DOS CD-ROM driver for a SCSI controller that has no Windows drivers.
In rare cases, it can happen that you install a DOS tool or driver that doesn't play nice with Windows, interfering with it or entirely preventing it from booting. In that case, you would put those commands somehwere else: On a boot disk, in a custom boot menu or in a custom PIF file, so that they are only loaded in a pure DOS environment.
If it's something as simple as a sound or mouse driver, I'd simply have it install to the default autoexec.bat and config.sys. If it's something that can potentially mess up Windows, such as DOS network drivers, I put it into a custom config.
About DOSSTART, I never even knew this existed until the above post by Errius. Where did you read that you should be using it? It's just one of many ways to get things done, but by no means mandatory. If it's not there, MS-DOS mode will simply use the regular autoexec.bat.
Reply 4 of 16, by DustyShinigami
asdf53 wrote on 2025-11-21, 16:23:
You can absolutely modify config.sys and autoexec.bat, that was the norm back then. In fact, there are cases where this is neede […]
Thanks
Oh. Yeah, that's what I figured. Unless I just misunderstood someone's post in another thread. But no, that makes total sense. That could be what they meant as a particular driver is preventing Windows from booting. So I guess that's what they were suggesting. Though it was mentioned the CD and mouse drivers shouldn't be in the autoexec. These particular drivers in question are DOS audio drivers for my Sound Blaster Audigy 2. Along with a patch.
DOSSTART is completely new to me, too. That was also mentioned in the other thread.
But I'll look into creating a custom PIF file for these drivers and any future ones that cause problems. Thanks. 😀
OS: Windows 98 SE
Reply 5 of 16, by asdf53
That's just two different approaches of doing it.
One might say: 99% of MS-DOS drivers are not needed for Windows and could potentially cause problems, so you pre-emptively move them out of the default autoexec.bat and config sys and only load them in pure DOS. That's perfectly valid.
My approach is, leave everything in by default and only if problems occur, investigate and move it out. This is more convenient to me because I rarely ever encounter problems.
A PIF file is simply a set of custom MS-DOS config.sys and autoexec.bat commands that are different from the default ones. Either a standard PIF for the "Reboot to MS-DOS mode" session (it's "C:\Windows\MS-DOS mode.pif" or something), or a custom one on a per-game basis (example: a "mygame.pif" that might load a particular memory manager for DOS, often needed for problematic games) that you would put on your desktop and double-click to play the game.
Reply 6 of 16, by Joseph_Joestar
DustyShinigami wrote on 2025-11-21, 16:58:
To clarify what I said in the other thread, DOS drivers are 16-bit. Windows 9x drivers are generally 32-bit. It's not a good idea to load both at the same time (e.g. both a DOS and a Win9x CD-ROM driver). This can be avoided in several ways. One is to create a custom PIF file, as Phil shows in his video.
The other is to use DOSSTART.BAT and put any DOS drivers there. This file is found in C:\WINDOWS\DOSSTART.BAT and it is executed automatically when you click Start > Shutdown > Restart in MS-DOS mode. So you can put the mouse driver and other stuff that's only needed in pure DOS inside that file. You can read more about that here.
Personally, I prefer the custom PIF method, as it's much cleaner. There's also a third method of creating a dedicated boot menu which allows you to select between DOS and Windows, but I never used that.
My retro builds
Reply 7 of 16, by DustyShinigami
asdf53 wrote on 2025-11-21, 17:18:
That's just two different approaches of doing it. […]
Yeah, that would be my approach, too. Only if I encounter something that's an issue would I isolate it to its own file. The SB DOS drivers I would personally use only for specific games and would only call for it in a custom BAT file. Whilst I'm testing and experimenting though, I've added them to the main autoexec file. Memory managers are another example too as I know some games are very picky if they're enabled or not.
OS: Windows 98 SE
Reply 8 of 16, by DustyShinigami
Joseph_Joestar wrote on 2025-11-21, 17:23:
To clarify what I said in the other thread, DOS drivers are 16-bit. Windows 9x drivers are generally 32-bit. It's not a good ide […]
Ahh, I see. Gotcha. I'll certainly look at playing around with custom PIF files and the DOSSTART file. I'm all for cleaner and more organised approaches especially now I have a clearer understanding of how they work. Although I'm guessing I'll need to learn how to call the various drivers in DOSSTART.
OS: Windows 98 SE
Reply 9 of 16, by chinny22
I'm also a lifetime member of the custom pif camp.
The main thing to remember is never modify autoexec.bat /config.sys while in dos mode. Always do it in the Advanced section of the shortcut (4:09 in the Phil video linked above)
The other advantage not loading things in Windows copy of autoecec/config.sys is the splash screen is visible longer, very important! 😉
Reply 10 of 16, by NeoG_
I think it's impossibly hard to have a complex working DOS environment inside the autoexec.bat and config.sys files that run before 95/98 launch. It makes a whole lot more sense to maintain two configurations and use a PIF file to swap between them transparently.
I replaced the standard Exit to DOS.pif file in the windows directory with the custom DOS environment shortcut so you can access the custom DOS mode under Shutdown -> Exit to MS-DOS which is cool.
chinny22 wrote on 2025-11-25, 05:46:
Is there a specific reason for that? When I did it any changes made were copied back to the PIF shortcut automatically (in 98SE)
Reply 11 of 16, by DustyShinigami
Great, thanks. Yeah, I was in the habit of editing them whilst in DOS. ^^;
As to your last sentence - I'm currently experiencing the Windows splash screen being visible for longer. Much longer. Nearly a minute in fact. I mentioned this in another thread I made. I think both autoexec and config are currently empty, though I don't recall the logo showing this long in the past prior to adding things to them.
OS: Windows 98 SE
Reply 12 of 16, by NeoG_
DustyShinigami wrote on 2025-11-25, 11:30:
I think the most common cause for this is that there is an active ethernet interface set to DHCP, the network driver will attempt to obtain an IP address before the GUI loads even if no cable is connected and it will sit there doing nothing for 30-60 seconds. Assigning a static IP address can speed it up.
Reply 13 of 16, by DustyShinigami
NeoG_ wrote on 2025-11-25, 11:46:
Oh. Okay. I mean, the system has never been set up or configured for any kind of networking. What would be the thing to do here? Is there something I need to change in the BIOS maybe? Configuring networks isn't my strong suit when it comes to PCs. ^^;
OS: Windows 98 SE
Reply 14 of 16, by NeoG_
DustyShinigami wrote on 2025-11-25, 12:06:
If the computer has a built in ethernet port and you are not planning on using it, you should be able to disable it in the integrated peripherals section of the BIOS
Reply 15 of 16, by DustyShinigami
NeoG_ wrote on 2025-11-25, 23:35:
If the computer has a built in ethernet port and you aren not planning on using it, you should be able to disable it in the inegrated peripherals section of the BIOS
Ah, I see. I've just checked, but no, this motherboard doesn't have an ethernet port. And no option in the BIOS either.
OS: Windows 98 SE
Reply 16 of 16, by chinny22
[/quote]
I've had it, and know others here as well where if you edit say autoexec.bat while in dos it'll change the "real" one. sometimes causing a loop when trying to exit back to windows.
However I simply had a shortcut to command.com on my windows desktop. Maybe you replacing the inbuilt Exit to Dos.pif has a few more safeguards?
When Windows loads it'll show the splash screen at the start but if you have anything in autoexec/config.sys it'll replace the splash screen with text generated from those commands.
Actual boot time shouldn't really change though? if anything would think it was 1-2 seconds faster as it's no longer loading dos drivers
