First post, by Lostdotfish
I've got a Voodoo 2 card that is recognised in Windows 98 device manager - but the drivers don't load and MOJO hangs when you try and run it.
Initial inspection of the board discovered this.
Whatever went wrong with this card it blew out the 5V+ side of the traces on FB10 and C181.
I replaced these and the dodgy looking components nearby but still no change in the card's behaviour.
Testing and investigating further, I discovered that I have a short to ground somewhere (kicking myself a little that this wasn't the first thing I checked for). I've started pulling some caps out of circuit but the short to ground is still there.
Any advice on how best to track down the short? I've pulled most of the 4.7uf caps out of circuit now but the short persists.
