First post, by lucac81
Hi guys,
I have a T5515 thin client from hp which i am happily using with freedos that i wanted to use also with windows98 and while the ram is not a problem (updated to 256mb) i have big constraints on the storage side having only 128mb on board.
Freedos happily runs from usb thumbdrive, but i don't know if win98 likes it.
all the SD card or CF adapters i have found are just too big to fit between the pci slot and the metal enclosure unless using a flat cable, but i have nowhere to attach the adapter inside the case.
So I have found replacements on ebay like this one:
https://www.ebay.it/itm/296932436494?_trksid= … 87VTNW6ATB3RPA9
Is 16GB enough to install windows98 and games? can in then install some into an usb drive?
Reply 1 of 3, by Yoghoo
lucac81 wrote on 2025-11-24, 16:56:
That is more than enough for Windows 98 and a lot of games. You can install games on USB but it's probably not needed (and also slow). Games around that time were mostly a couple of 100MB. And the bigger/later games would probably not run great on this CPU/GPU anyway.
Reply 2 of 3, by The Serpent Rider
16 Gb is above average HDD size for Windows 98 system. Also you can freely use USB 2.0 sticks as additional storage to load ISO files, etc.
Reply 3 of 3, by lucac81
Well, the 16gb is overall cheaper so i'll go for it, thanks
