First post, by unluckybob
Think anyone would not realize its windows 10 ?
The attachment untitled.png is no longer available
Reply 1 of 6, by unluckybob
I still have a few bugs to fix but its a good 90% usable.
Reply 2 of 6, by leileilol
probably so deeply modified it'd be kicked by anti-cheats and break on updates by that point. also the start menu's still flat and you'd still have the issue of apps mandating light/dark themes to break this illusion.
also win95 didn't have caption gradients and the 16-color icon set with full color icons enabled.
long live PCem
Debian's fucked
Reply 3 of 6, by unluckybob
updates worked fine, 10 no longer gets updates so even if it did not work it would not matter anymore.The core OS was harldy touched as its mostly a shell swap, dark/light mode is disabled with the shell swap so apps don't call it. Nothing of the windows 10 explorer shell is running. Its running a modified windows 2k explorer shell.
caption gradients was something I could not do much about as most of the underlining shell is windows 2k based, same goes for full color icons.
Reply 4 of 6, by unluckybob
I had anther project like this years ago were I made a custom user shell with a full screen CMD on windows 7, I"m trying to find a screen shot of it but it was close to 10 years ago so I likely don't have it any more.
Reply 5 of 6, by UCyborg
Don't you have to disable access to shared memory section dealing with theme in winlogon.exe to make it fallback to 2K style?
Arthur Schopenhauer wrote:
A man can be himself only so long as he is alone; and if he does not love solitude, he will not love freedom; for it is only when he is alone that he is really free.
Reply 6 of 6, by theelf
unluckybob wrote on 2025-11-29, 02:50:
retrobar or you manage to fix native one? i never fix 10 or 11 taskbar to look right
There ir a fix for flat menu on windhawnk
