First post, by retep_110
I am at the verge of building myself a ultra fast winxp retro gaming rig ( wPCI Express)with a GIGABYTE GA-P35 mainboard. I will pull the trigger for the mobo and the cpu tonight.
Im also looking for great sound card. In my thread asking about a suitable mobo the soundblaster xi-fi soundcard was recommended. When searching for that card in the www i found out that there are different models.
Is one model more preferable than others form a pure retro gaming (winxp) standpoint) or would be any x-fi card a good pick?
Reply 1 of 10, by Joseph_Joestar
retep_110 wrote on 2025-12-01, 07:01:
First, you need to decide whether you want a PCI or PCIe version of the X-Fi. Then, look here: https://en.wikipedia.org/wiki/Sound_Blaster_X … Fi#X-Fi_line-up
Avoid any "Xtreme Audio" models, as they don't have hardware acceleration for EAX. Also, don't buy a Titanium HD (emphasis on HD) since it doesn't have WinXP drivers, unlike other Titanium cards. Everything else should be fine, and it depends on how much money you want to spend.
Reply 2 of 10, by retep_110
Joseph_Joestar wrote on 2025-12-01, 07:15:
Thanks for the info. I was not a aware that there is PCI version as well. I am going to use PCIe mainboard so only the PCIe version is an option. You helped me to avoid a pitfall. Also thanks for providing a link. I will check it out asap.
Reply 3 of 10, by NeoG_
You basically have 3 models you can get;
SB0880 X-Fi Titanium PCIe
SB0886 X-Fi Titanium Fatal1ty PCIe
SB0888 X-Fi Titanium Professional PCIe
Reply 4 of 10, by ott
Actually, original PCI X-Fi cards (EMU20K1 based) are pretty good in terms of versatility.
I have PCI X-Fi Fatal1ty Edition (with I/O drive) and I'm quite happy with it. I also wanted to get PCIe version Titanium Fatal1ty Champion (EMU20K2), but later changed my mind.
PCI X-Fi Fatal1ty Edition notes:
- Available drivers for Windows XP to Windows 10 (Win 11 also works without memory integrity)
- X-Fi I/O drive fully compatible with older Audigy 2/2ZS cards. In contrast, PCIe version of I/O drive box has been cut down - lacking SPDIF and MIDI inputs/outputs
- Stable work on PCI-PCIe bridge mobos (tested on ASRock Z77 Pro3, Gigabyte B85-HD3-A)
- The card itself looks amazing with gold-color connectors
Reply 5 of 10, by shevalier
NeoG_ wrote on 2025-12-01, 09:33:
You basically have 3 models you can get; […]
All models in the 8xx series are very disappointing.
Creative tried to keep the price the same as PCI cards, but with a more expensive Digital component (RAM&DSP).
Their analog power supply is a parody even of PCI-e Audigy RX v2 (which has a CS4382A DAC, not a CS4382)
If you don't want to be disappointed, go for the Auzen X-Fi Forte 7.1 or Titanium HD.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 6 of 10, by Joseph_Joestar
ott wrote on 2025-12-01, 09:47:
Also, I think PCI X-Fi cards aren't subject to the OpenAL bug, which is present on PCIe cards when using newer drivers.
On the other hand, there are reports of PCI cards sometimes suffering from crackling/popping on certain motherboards, but that might depend on the chipset.
Reply 7 of 10, by retep_110
Thanks a lot for the further information. I will take a closer look at the recommended cards ASAP. Is there anything in particular to note concerning the drivers for WinXP gaming?
Reply 8 of 10, by Joseph_Joestar
retep_110 wrote on 2025-12-01, 11:47:
For PCIe X-Fi cards, you need to use driver version 2.17.0008 or older. Newer drivers introduce bugs with games which use OpenAL (e.g. Unreal 2, Doom 3, BioShock etc).
Reply 9 of 10, by ott
For original PCI X-Fi:
I prefer latest web driver for Windows XP, it's quite minimalistic and ready for gaming!
Fun fact, it's still available on Creative's site: SBXF_PCDRV_L11_2_30_0004.exe (README notes)
But I need some Creative apps, so I first install the CD driver with selected apps, then install the latest web driver - it automatically uninstalls the old driver.
Reply 10 of 10, by retep_110
Joseph_Joestar wrote on 2025-12-01, 15:51:
That is good to know thanks for the info. I have already thought that using older drives might cause some issues for certain winxp games.
