First post, by feipoa
Does anyone know how fast of a PCI clock the Voodoo2 will tolerate? For example, is 50 MHz a safe upper limit in an AT case? What about 60 MHz? How many extra MHz does using heatsinks of the FBI and TMU's help? Assume a standard use case, so maybe 3 hours of game play per sitting. Thanks!
Reply 1 of 3, by sdz
Voodoo2 runs fine at 66MHz. It's even rated for that. I pushed it beyond 66MHz, but it was quite a few years back, and I don't recall exactly what's the limit (maybe around 75MHz?)
Running the card at 66MHz PCI bus won't increase TMU temperature, maybe only the FBI, but not by much.
I wasn't able to measure any performance difference when running at 33MHz vs 66MHz.
Reply 2 of 3, by The Serpent Rider
There was Voodoo 2 for AGP. So 66 MHz should be fine.
Reply 3 of 3, by Disruptor
The Serpent Rider wrote on 2025-12-03, 13:29:
Indeed.
But it did not use any of the AGP features.
It just treated the AGP as 66 MHz PCI.
