First post, by DieSkaarj
Hello Vogons,
Has anyone here had a similar experience where when playing sound a CMI8738 PCI-e card (as seen in PhilsComputerLab) just straight out restarts the PC?
For background I am trying to get this card working inside a Win98SE VM. However the instability is present wherever the card is in use, on Windows 11, Linux (Void,) and through QEMU. The peculiar thing is that there is more stability with it running inside the VM using the VxD drivers available from Vogons. The sounds play fine in the OS until a game is started and then the entire unit resets.
I have tried to reconfigure the BIOS by setting the PCI bus related options to gen_1,2. I have disabled the OnBoard HD Audio. It might be worth noting that I'm using an AM4+ board, the MSI B350 Gaming Plus with a 3200G CPU. And, it's not just that board that has the same behaviour. It's other AM4+ boards with different CPU's.
It's not the first CMI8738 card I've tried either as I thought the first one was faulty, with it being a cheap chinese shite-y clone, but same issue persists. Again, on another CSC (Cheap Shitey Clone.)
I suspected that it was perhaps a memory issue (ReBar was disabled in BIOS also,) and have got yer another CSC, one that is advertised as being 32/64 bit and compatible with Win10. But, there's no ground for thinking this other than marketing.
Can anyone advise or have another PCI-e soundcard suggestion that can work on 9x?
Best regards,
David
