First post, by ndstudio
Hey all,
I am having limited success getting Windows 98 SE running on a somewhat modern PC (specs below) using the standard method of installation.
Specs
Motherboard - Asus Z97M-Plus
CPU - Intel Core i7-4790K
Ram - 8gb DDR3 RAM (single stick)
Hard Drive - 128 SSD (32gb partition)
PCI Bus
GPU - VooDoo3 3000 PCI (set as primary GPU in BIOs)
Audio - Terratec Promedia TTSOLO1-N Ver 1.1 PCI (ESS Solo-1)
PCI-E Bus
USB - Startech VIA 6212 USB 2.0
GPU - nVidia GeForce GT 730 4G GK208 (for booting into other systems like XP and Win10 and etc)
I am able to get everything setup and successfully boot into Windows 98 SE using the Patchmem patch. However, after the installation I need to install the various PCI cards and this is where I am having issues. Basically after manually installing the PCI Bus in device manager and restarting the computer all I see is a blinking cursor. Going into Safe mode and removing the PCI Bus fixes the issue. I have tried installing the Loew SATA patch but this didn't change anything. I am only able to gain access into Windows 98 SE by removing the PCI Bus device in the device manager...
Other installation methods like the Quickinstall work just fine. So I know its possible to install Windows 98 SE with the PCI Bus working with my hardware.
The obvious question is, (why don't I just use the Quickinstall method). The reason why I'd like to get Windows 98 SE installed the standard way is to both have the full copy of Windows 98 SE installed and to test an issue I have with the Terretec TTSOLO1-N audio card. I have another thread open about this issue here -> Re: ESS Solo-1 Wavetable Header No Sound - Win98 - es1938s, basically this issue deals with the drivers not adding the "AuxB" slider to the mixer so I am unable to hear any playback from the Wavetable daughterboard. So I'd like to see if a full installation of Windows 98 SE with everything intact would fix this weird issue.
Anyways, any help with this would be greatly appreciated. I feel that I have gotten so close to getting everything running smoothly.
