First post, by Retroplayer
This laptop uses a 3 pin circular connector. The original power supply is PN LEP-9100-AC
Leading Edge computers were apparently manufactured by Daewoo.
If anyone here has this laptop or power adapter, I could really use some help if you are able to measure the voltages on the pins. I have the mating connector already.
