First post, by zuldan
Sometimes you get lucky on eBay. I came across a Gainward 7800GS for Parts/Repair. It had been listed for about 24 hours. I grabbed it for $26 USD. I wasn't 100% sure it was the version with 24 pipes (the model labelling didn't have the "-GS" suffix") but after confirming with GPU-Z it had 24 pipes and core labelled G71, I knew I had struck gold! (https://www.techpowerup.com/gpu-specs/gainwar … en-sample.b8222), the fastest Nvidia AGP card. The card is in excellent condition. Just one small problem....artifacts (which I knew from the listing). I've attached the MATS log.
Here are some great links to verify which version you have;
https://warp9-systems.proboards.com/post/43210/thread
https://forums.overclockers.co.uk/threads/gai … 0/post-11466208
The attachment s-l1600.webp is no longer available
The attachment GS.jpg is no longer available
The attachment IMG_20251206_125430.jpg is no longer available
The attachment IMG_20251206_125417.jpg is no longer available
MATS 75 log
The attachment 7800GS.TXT is no longer available
Reply 1 of 11, by zuldan
It looks like C and D chips have issues. Next step is to find where they are located on the board and if replacements are available.
The attachment MATS.png is no longer available
The attachment 20240807_084332.JPG is no longer available
It appears the memory chips are "HYB18H512321AF-14". Unfortunately, no one sells this exact model anymore.
Options are ;
- Try the identical model but slower speed "HYB18H512321AF-13". https://www.aliexpress.com/item/1005008640348104.html (this would involve dropping the memory clock to 675 MHz).
- Try a slightly different model with identical specs (I think) https://www.aliexpress.com/item/1005007174051898.html
- Find other cards that used "HYB18H512321AF-14" and harvest from that. Maybe a 7800GT PCIe ?
Reply 2 of 11, by zuldan
I think the memory order goes like this for older cards. I've highlighted the bad chips. The MATS log says bank 0 (EB0) and bank 1 (EB1) of D has errors as well as C0. In this situation, that is referring to a single chip. On something like a 7800GTX bank 0 is on the front of the card and bank 1 is on the back of the card, two different chips.
Since D1 has millions of errors, a reflow of the chip is probably not going to work. A reflow of C0 might work since there aren't too many errors. In any case, I'm going to replace both chips since it's such a rare card.
Reply 3 of 11, by zuldan
I replaced D1 and reflowed C0 but now there are more memory errors. I think the next step is going to be reflowing or reballing the core.
  LANE    EB0 READ ERR EB0 WRT ERR  EB1 READ ERR EB1 WRT ERR  UNKNOWN ERR
FBA[31: 0] 0 0 0 0 0
FBA[63:32] 0 0 0 0 0
FBB[31: 0] 0 0 0 0 0
FBB[63:32] 0 0 0 0 0
FBC[31: 0] 753975 24244283 945925 24040487 0
FBC[63:32] 0 0 0 0 0
FBD[31: 0] 7093405 18112739 6987330 18218174 0
FBD[63:32] 98 16817461 194 16816754 0
Reply 4 of 11, by myne
Voltages?
Tried underclocking?
Checked smd caps nearby for shorts?
Mats is brilliant, but it can only point in the general direction of the fault.
It doesn't mean necessarily that the first assumption is correct
I built:
Reply 5 of 11, by zuldan
myne wrote on 2026-01-03, 05:33:
Voltages? Tried underclocking? Checked smd caps nearby for shorts? […]
Voltages?
Apologies for the late reply. Had to jump to some other retro duties. I've had some time to come back to this . Can't find any shorts. Voltages appear to be OK although I don't have the schematics for this card to double check.
Reply 6 of 11, by zuldan
I've installed a new core...
The attachment 6923322F-48AD-4D46-BA96-0720A6C801FD.jpg is no longer available
The attachment image.jpg is no longer available
and replaced the memory using memory from a harvested card (https://theretroweb.com/expansioncards/s/ati- … -xt-pci-e-256mb) plus reballed as these chips can't be purchased anywhere. I confirmed the memory on the card was working perfectly before harvesting.
The attachment 74f08e20-7d16-4602-9b6a-6dabd90aa406.jpg is no longer available
The attachment IMG_0129.JPG is no longer available
Unfortunately, exact same issue exists. So there must be a component on the board that's dead that I can't identify. I've been told by someone who repairs a lot of AGP cards that these 7800GS's are almost impossible to repair. A bit disappointing considering the amount of time I've put into this card but as they saying goes, you win some and you lose some...
Here are some resistance measurements in case anyone needs them for their card in the future.
The attachment 7800GS - Resistances.jpg is no longer available
Reply 7 of 11, by myne
I'd be suspecting the bridge chip if everything else checks out
It doesn't look like you protected it from the heat either
Scratch that. I just read through the thread again
OK. So it works, but one memory channel is bad. Yes?
If you have an appropriate donor, swap all the smd components around that chip.
I built:
Reply 8 of 11, by myne
These traces may be damaged by screws, handling, and time
I built:
Reply 9 of 11, by myne
The red looks sus too
I built:
Reply 10 of 11, by zuldan
myne wrote on 2026-03-08, 03:17:
I'd be suspecting the bridge chip if everything else checks out […]
2 mem chips are dead. D1 and C0.
Unfortunately I don’t have a donor board, but yes swapping all the components would be a good idea.
I’ll have a closer look at that screw hole. Thanks for the heads up.
Reply 11 of 11, by myne
Look for 8 and 9x00s with the same memory size and bus width.
They're dirt cheap and given the way tech works, in all probability they will have the same bga footprint and slightly better specs.
I doubt there will be any compatibility issues running faster chips with slower timings.
Eg https://www.techpowerup.com/gpu-specs/geforce-9600-gt.c206
They're cheap. Even sticking with gainward for the probability that they use the same bga footprint
https://www.ebay.com/itm/397462059319?_skw=Ga … atedSearch=true
I built:
