First post, by KIng Mustard
I highly expect not but I thought it best to check before I order some 3.5' floppy disks in order to reinstall Windows 98SE on the machine.
Reply 1 of 10, by Babasha
KIng Mustard wrote on 2025-12-07, 15:37:
Yes. Just use PLOP BOOTLOADER from your HDD or burn it in 32KB ROM and use with bootable cards (something like network cards with boot-rom socket).
Need help? Begin with photo and model of your hardware 😉
Reply 2 of 10, by KIng Mustard
Babasha wrote on 2025-12-07, 17:37:
I do not have a floppy disk nor CD writer.
Is it possible to boot from a USB flash drive without these?
Reply 3 of 10, by NeoG_
The AladdinV as far as I know can boot from Floppy, HDD, CD-ROM, ZIP and bootrom from an add-in card. The onboard USB controller doesn't interact with the BIOS at all. I had an IDE CDROM so was able to boot the Win98SE CD-ROM. If you are using an SD2IDE or CF2IDE you can write an installer image to the cards to boot from.
If all you have is a floppy drive and a spinny HDD then you would either need a bootable floppy or a way to inject the bootable files onto the HDD using a USB adapter on a modern system.
Reply 4 of 10, by Babasha
KIng Mustard wrote on 2025-12-07, 21:54:
Yes you can boot from USB flash drive. I make my 8gb flash drive bootable just format it inside Win98 and copy system files with SYS <DRIVE LETTER>
Reply 5 of 10, by shevalier
On ALI 5, the chances are close to zero.
The earliest I've seen is Intel 815 S370 from Aopen.
And even then, this option is more likely to not work than to work.
It probably appeared in the P4/AXP era.
If the BIOS does not explicitly state that USB storage has been detected, then it definitely won't work.
upd
That's not entirely correct.
Booting from a USB flash drive appeared in version Award BIOS PG 6.
It was not present in version PG 4.5 at all.
This wording would be more accurate.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 6 of 10, by Babasha
shevalier wrote on 2025-12-08, 11:36:
On ALI 5, the chances are close to zero. The earliest I've seen is Intel 815 S370 from Aopen. And even then, this option is more […]
Just use PLOP BOOTLOADER as i write early
I use it to BOOT from MBR or as ROM extension from socket on network card (or Y2K fixer card)
Success with Intel ML430HX, TC430HX, Forex and OPTI Socket4 and Socket5 motherboards...
Reply 7 of 10, by shevalier
Babasha wrote on 2025-12-08, 11:50:
Just use PLOP BOOTLOADER as i write early I use it to BOOT from MBR or as ROM extension from socket on network card (or Y2K fix […]
I can boot via PXE over the network, but the author of the thread asked about USB flash drives. 😀
Personally, PLOP did not boot from USB when I experimented with a 3COM network card.
I will need to look for a compatible network card from Realtek and conduct a few more experiments.
Reply 8 of 10, by NeoG_
Assuming you buy said floppy disks, where were you going to source the 98SE install files from after formatting the drive? Do you have a non bootable 98SE CD-ROM?
Reply 9 of 10, by Babasha
shevalier wrote on 2025-12-08, 12:18:
I can boot via PXE over the network, but the author of the thread asked about USB flash drives. :-) […]
Meanwhile i dont boot over LAN but boot from USB with onboard or PCI USB cards 😀))
Reply 10 of 10, by shevalier
Babasha wrote on 2025-12-08, 12:19:
I'm telling you, the 3COM network card didn't want to work with Plop.
Plop loads on its own, sees the flash drive, but then the loading stops.
I have a Compex RL2000 with a dip socket.
I'll have to experiment to see if it works at all.
PS The RL2000 turned out to be a Winbond W89C940.
Additional cards are already available for it, allowing you to run additional ROMs.
For example, the same Plop Boot Manager.
