First post, by Tawkalin
Hi guys i found
The attachment Screenshot_2025-12-07-20-30-47-833_com.dolap.android-edit.jpg is no longer available
The attachment Screenshot_2025-12-02-20-34-16-091_com.dolap.android.jpg is no longer available
4 dolar seller says its working.
i have this slot pc can i connect gpu to this guy?
The attachment Screenshot_2025-12-02-14-11-36-706_com.dolap.android.jpg is no longer available
Reply 1 of 7, by NeoG_
Looks like it's specifically designed to work with the IBM 4694-001 and 4694-004 point of sale system. Probably won't work with anything else unless you get the pinout and make your own adapter.
Reply 2 of 7, by zyga64
I wouldn't call it a GPU 😉
There's no acceleration whatsoever, not even 2D. Just SVGA with 256 color maximum.
However I expect it to be faster than the Trident 9000i 😀
8088@8 /640k /Genoa CGA /TNDY 3voice
286@20 /4M /CL-GD5422 /CMI8330
486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
K6-2@400 /64M /MGA-2064W+3dfx /YMF718
P!!!750 /256M /MX440 /Vibra16s+SBLive!
Reply 3 of 7, by Tawkalin
zyga64 wrote on 2025-12-08, 08:33:
Its cheap and cute my slot pc have 865g onboard gpu its better ofc but it will be nice accessory
Reply 4 of 7, by Tawkalin
Thx for mobo name. Maybe i can found motherboard schematics and look for Pinouts
Reply 5 of 7, by wierd_w
The connector has 36 pins. I'd wager it's a variant of 16bit ISA, with a lot of pins omitted.
As for the mentioned IBM POS terminal's mainboard, I am having a hard time identifying the requisite socket.
There is a current ebay listing for such a system's mainboard, which has a useful picture.
https://i.ebayimg.com/images/g/i6gAAOxyirJSGAiQ/s-l1200.jpg
(From this listing)
https://www.ebay.com/itm/274172329816
Reply 6 of 7, by twiz11
Tawkalin wrote on 2025-12-07, 17:39:
Hi guys i found […]
Hi guys i found
if you bought that for 4 bucks keep it, might go up in value if AI scalpers look for anything to get their hands on
Reply 7 of 7, by NeoG_
wierd_w wrote on 2025-12-08, 21:01:
The connector has 36 pins. I'd wager it's a variant of 16bit ISA, with a lot of pins omitted. […]
(From this listing)
It looks like a different revision of the board, you can see a couple of extra connectors on this 4694-004 board
There is 2x 34 pin connectors for a total of 68 pins
https://i.ebayimg.com/images/g/mxMAAOSwPUVdSIoT/s-l1600.webp
https://www.ebay.com/itm/113844434396
