First post, by wbahnassi
Hi guys, I have this 286 motherboard:
https://theretroweb.com/motherboards/s/leadma … inc-lm-103fs-16
It came with quite some bad battery corrosion. After a few days of carefully fixing the traces, it came back to life again. Upon first attempts, it just showed a dreaded "CMOS Inoperational" message and refused to go further into POST. I suspected the RTC module (HM6818P, I believe this is a clone of https://theretroweb.com/chips/2644 ). It probed fine, but I noticed very weak signals on the data line between it and the keyboard controller (DAC-PCKB42).
I replaced the keyboard controller with another AMI (KB-BIOS-Ver-F, P8042AHP) and the motherboard booted up properly without any issues, and I was able to run DOS and run benchmarks without issues.
Now I wanted to slow down the motherboard via the turbo switch header. This is JP1 on the board, and it has 3 pins. If I short pins 2 and 3, the Turbo LED lights up. Otherwise it goes off. However, whether the turbo led is on or off, I see no effect on the CPU speed at all. It just stays at full speed (12MHz).
There is another pin header JP2 that also has three pins. If I short 2 and 3, the benchmarks jump to 16MHz (according to TopBench/Landmark/SysInfo).. I believe this is a wait state setting of some sort. But regardless of this setting, the turbo switch is still not making any effects.. I expect it to halve the CPU speed when disconnected.. but right now it just does nothing.
I traced the 25MHz oscillator to go into one of the pins of the GC101A chipset. I also traced the middle pin of the turbo switch header to go to another Headland chipset. This leaves communication between the main and the other chipsets, which is difficult to trace further because I have no datasheets for these chipsets.
If I probe the CLK signal on the CPU, I can see that it starts at 12.5MHz upon boot, until the POST starts loading MS-DOS, then CLK jumps to 25MHz and stays there. So the chipset must be controlling the speed according to some logic/settings. Some BIOS setup programs provide an option to choose the CPU speed at boot (slow vs fast), but the BIOS setup program is quite basic and only offers: time,HDD,FDD,monitor and scratch mem for BIOS. No other advanced options.
I tried the BIOSes from TRW's page, and they're both identical when it comes to exposed options. I also tried MR BIOS, but that one didn't offer any speed controls either.
I know some boards used a separate SETSPEED program to control the turbo functionality. But I always thought the hardware switch would take precedence. Anyways, I'm not sure if this board uses such a tool, so any idea if this is the case here? Or perhaps it is still some severed connection that is preventing the turbo switch signal from reaching its end point? Again, the turbo LED responds fine to the turbo switch..
I'm puzzled 😵‍💫
Turbo XT 12MHz, EGA, MFM HDD
Intel 386 DX-33, Speedstar 24X, SB 1.5, 1x CD
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
IBM BlueLightning 100MHz, CL5428, SB16, 4x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, RTX2060
Reply 1 of 7, by wbahnassi
Managed to find a set of generic setup programs and a speed utility from here:
https://www.minuszerodegrees.net/software/
The speed utility refused to work because the keyboard controller must be from Award, whereas mine is AMI. But this got me to highly suspect that this issue is caused by the replacement keyboard controller. Unfortunately the original one is completely dead, but it probably had the programming needed to handle the clock selection.. whereas the AMI replacement I added is missing on that, so I'm getting this behavior.
If this is the case then this board will be pretty much stuck in hi speed mode all the time..
Reply 2 of 7, by NeoG_
I was watching a necroware video recently about fixing a turbo issue on a 486 board and the keyboard controller acts as an input to the turbo system on some mainboards based on keyboard shortcuts hard coded into the controller IC. If the keyboard controller was replaced and it uses this pin for a different purpose, the turbo mode would act according to the logic on that pin.
If you probe the keyboard controller for any output pin which changes state at the same time the system goes from 12.5mhz to 25mhz during boot and you find one, lifting this pin will likely allow the turbo button header to work again.
The strange thing is though that you would expect the turbo light to be on even if you use the keyboard shortcut
Reply 3 of 7, by wbahnassi
Ok, I finally got to get back to this one. I did probe all keyboard controller pins, and I couldn't find anything that particularly corresponds to the turbo behavior I'm seeing. One of the keyboard controller pins was going high during the memory count, then going low as soon as counting is done. That's the A20 gate, and it's working fine. The turbo up behavior happens when Starting MS DOS shows up, so it's not correlated.
One thing caught my attention though is how the clock signal looks like at the CPU.. See the attachment. As if both 12MHz AND 25MHz are being fed at the same time.. even the scope is a little confused.. some times it reports it as 25MHz and sometimes 12MHz every second or so.. I don't think this is normal, no?
Reply 4 of 7, by NeoG_
Can you trace where the turbo header routes to? Which chip is controlling the turbo behaviour that takes this as an input?
Reply 5 of 7, by wbahnassi
NeoG_ wrote on 2025-12-18, 01:39:
I was only partially successful in my traces.
I traced the turbo switch to a NAND chip that fed into a flip-flop that fed back to the Turbo LED. So that solves why the turbo LED is working regardless of the actual chipset's decisions.
Now I expect that the output from the flip flop should also feed into the chipset to tell it about the turbo switch's state.. but so far I couldn't find the trace. Either it is severed by corrosion and I missed fixing it, or the output of this flip flop isn't used by the chipset (but that doesn't make sense.. as the whole point of relying on the flip flop is that it's in sync with the CPU's clock so turbo switch changes do not take effect at bad times).
The flip flop in question is SN74LS74AN. Here is its data sheet:
https://www.ti.com/lit/gpn/sn54s74
1D is ultimately connected to the turbo switch. It goes to 4.6V when the turbo switch is shorted and 0V when open. 1PRE and 1CLR are both always high at 5V. 1CLK is also connected to clock, and has the same signal shape I can see at the CPU (a mix of both 25 and 12.5MHz).
1Q goes ultimately back to the turbo LED.. and the turbo LED is lighting on/off correctly.
I'm trying to find now if I can trace 1Q or the inverted 1Q to anything else other than the turbo LED. But I have a feeling that I won't find anything else, and that would be the issue. That would be a bummer though because it will be tough to find the responsible broken trace.
Reply 6 of 7, by weedeewee
according to the little settings document on TRW
JP1 - "Hispeed" setting to chipset 101; pins 3-2 closed = ON (CLK*2 selected) open = CKLx2 /4. If left open CPU will go half as fast.
JP19 - TURBO LED
JP2 - TURBO; 3-2 = ON. TURBO is desabled on power on.
this would make me think the turbo switch should be connected to JP2.
my 2cents.
Do not ask Why !
Reply 7 of 7, by wbahnassi
weedeewee wrote on 2025-12-21, 21:53:
according to the little settings document on TRW […]
JP19 - TURBO LED
my 2cents.
While JP2 does change the speed, I don't think it's the standard turbo switch. My claim is because JP2 doesn't result in Turbo LED being affected, whereas JP1 does. Another consideration is that other motherboards using the same chipset name have a jumper called Dynamic Memory Wait State [0 or 1] in addition to TBSW. I think this might be the same as JP2 on my board. JP2 doesn't cause a clock change at all on the CPU.
Finally, JP2 is changing the benchmarks from 12MHz to 16MHz. The turbo switch usually halves the speed rather than overclock the CPU.
Scouring other boards with the same chipset, I noticed some of them have jumpers to allow keyboard control of turbo instead of hardware. I topk this one:
https://theretroweb.com/motherboards/s/chaint … -elt-286b-120gm
Tried it BIOS, and the BIOS exposes options to boot with fast or slow CPU and to change the wait state. Alas, neither of those options seem to be effective on my board. Furthermore, when I do Ctrl Alt + and Ctrl Alt -, I get a beep that reflects the choice of turbo (high pitch vs low pitch), yet no actual speed change is occuring.
This leads me to believe that my board is hardwiring the chipset to not allow keyboard control of turbo.. which is ok.. but I still want to fix the hardware switch.
Thanks for the suggestion anyways.
