First post, by pazur
Hi all, newbie here. Im coming through with a problem that maybe someone can help me with. Few days ago i came back to my old WIN98 PC project since i got sata/ide adapter and can use ssd now, either way, i have problems with my current display connected via dvi to hdmi adapter, im using Acer Predator X25 360hz and it loses signal at 640x480 resolution. At first it was almost not responding to any res but the default one, but after disabling DCC inside Powestrip 3.9 with other display i can now select everything from 800x600 to 1920x1080. I confirmed that my montior can in fact use 640x480 by creating custom resoluition on windows 11 in nvidia panel. On old pc side i use Radeon 9250 with catalyst 06.2 4.15.1.9165. It wouldnt be a big problem normally, but some games start in this res only which makes it impossible to play these games.
