First post, by Nahkri
I have a cracked resistor network ,it's right near the cpu socket,the markings on it read 1A 103J ,the board works fine,but i want to replace it.
Problem is, i can' t find a 103j resistor with 10 pins as the one on the board,just with 9 pins
Can i use any other one that has 10 pins?
Reply 1 of 1, by Locutus
It is a 9 x 10k ohm resistor array - it should be available in every shop around.
If you have an 8×10k array, you can always add a separate resistor .
A perfectly functional solution... worthy of blacksmith craftsmanship 🙃.
The attachment Capture.JPG is no longer available
