First post, by Takino-42
So I have a MS-6163 Pro board that in theory should support 133fsb and even has jumper instructions printed for 133 on the board itself, but I actually wonder how stable it handles em. Unfortunately I don't have the RAM and GPU to test it for now, but another question is, can capacitors handle it? Was reading on the internet that capacitors on these boards were total junk and could damage the other componenets too and wonder if I need to replace em. The capacitors itself are from Tayeh and aren't bulging, leaking, but I don't really wanna waste my coopermine 133FSB PIII on this if it's gonna run at all. Now the last question, I've seen some old boards having their old electrolytes replaced with SMD polymers, is it really possible or it's just better to replace it with equal electrolytes of good quality? Anyway, I would wanna know how stable is 133FSB on this board for other people.
Reply 1 of 17, by Takino-42
forgot to mention... ain't a pro in capacitors...
Reply 2 of 17, by bofh.fromhell
I've never seen bad caps actually damage other components (other then corrosion from the electrolyte).
Usually you just get instability at higher frequency's or worst case no POST.
Also obviously 133MHz FSB is a decent overclock and pretty far out of spec for PCI and AGP (and even the IDE controller IIRC).
So even if the MB is happy at 133 (some were not, even if they had settings for 133), those components need to tolerate 33% out of spec.
So if it was me doing your setup I'd start the system at 66MHz FSB and do some fast stability tests.
Then go 100MHz and repeat.
After that its just a matter of losening all mem and PCI/ISA timings and going for the OC, usually via whatever steps the MB has between 100 and 133.
Reply 3 of 17, by Takino-42
bofh.fromhell wrote on 2025-12-13, 19:22:
I've never seen bad caps actually damage other components (other then corrosion from the electrolyte). Usually you just get inst […]
oh dear I never knew IDE controllers get overclocked too 🤣, wouldn't be surprised if hard drives would get burned up. I'll notify if my tests gonna successful but since I ain't got parts, then not anytime soon
Reply 4 of 17, by shevalier
Takino-42 wrote on 2025-12-13, 13:15:
For example, the same Pentium MMX on an MVP3 motherboard with electrolytic capacitors glitched at 100 MHz FSB even at a supply voltage of 3.2 volts (100*2.5=250МГц).
Even with non-branded polymer capacitors, it is stable at 2.8V on the same 100MHz FSB.
But it still doesn't take 100*3=300, alas.
So they have a positive effect.
But if you didn't win the silicon lottery, polymer capacitors won't be a panacea.
133 MHz for 440BX is basically a working option, but not a guaranteed one.
The IDE controller, incidentally, like the PCI bus, will operate at a native 33 MHz.
Provided that the BIOS correctly supports 133 MHz FSB.
In short, it's a decent idea.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 5 of 17, by PcBytes
In theory it's a good idea.
In practice? Forget about it. The 6163, across rev 2.0 and 3.0 (I have both) are horribly finnicky with polymers installed.
And 133 FSB on 6163? Also forget about it. None of the boards I've tested EVER did 133FSB properly, and that's caused by the Cypress clockgens MSI loved to use during the P3 era. Best bet if you want 133FSB is getting a retail MS-6199VA, which is basically 6163 but with VIA 693A. Might be less performant but at least it does 133FSB properly.
Reply 6 of 17, by Takino-42
PcBytes wrote on 2025-12-17, 18:49:
oh yeah I might just go with VIA chipsets then I guess, I saw some good chaintech boards with them supporting up to 1ghz coppermines and having just as good memory bandwidth so that should be worth it. i820s platform are rare n expensive anyway. Very thankful for the advice
Reply 7 of 17, by Takino-42
shevalier wrote on 2025-12-17, 16:33:
For example, the same Pentium MMX on an MVP3 motherboard with electrolytic capacitors glitched at 100 MHz FSB even at a supply v […]
alright I'll maybe consider it for other boards too!
Reply 8 of 17, by Takino-42
I know the thread is pretty late but I really need quick last tips on this. After checking MS-6199VA page on retroweb it seems to have IC-W196G clockgen in it, and after looking on my MS-6163, it turns out to have the same clockgen too luckily or not. Does anybody have boards or experience with 133FSB with this clockgen?
Reply 9 of 17, by PcBytes
Takino-42 wrote on 2026-06-07, 15:20:
The VIA variants will do 133FSB natively. 6163BX won't, and I can say this with confidence as my 6163 v2 and 3 couldn't do 133 either. Same 196G clockgen, which funny enough does 133 stable on ABIT's BH6 rev 1.1/1.2.
Reply 10 of 17, by TELVM
So I have a MS-6163 Pro board that in theory should support 133fsb and even has jumper instructions printed for 133 on the board itself, but I actually wonder how stable it handles em. Unfortunately I don't have the RAM and GPU to test it for now, but another question is, can capacitors handle it? ...
Provided the rest of the hardware can manage 133MHz FSB stably ... fresh, healthy, in spec caps will enhance stability.
Old, tired, out of spec caps will probably ruin stability.
... Was reading on the internet that capacitors on these boards were total junk and could damage the other componenets too and wonder if I need to replace em. The capacitors itself are from Tayeh and aren't bulging, leaking, but I don't really wanna waste my coopermine 133FSB PIII on this if it's gonna run at all ...
Tayeh ain't good caps. I wouldn't trust ~25 year old Tayehs, no matter how good they look from the outside. Sorry, sad fact.
... I've seen some old boards having their old electrolytes replaced with SMD polymers, is it really possible or it's just better to replace it with equal electrolytes of good quality? ...
I believe by "SMD" (Surface Mounted) you mean polymer thru-hole capacitors, aka "solid caps" or "polys".
It is perfectly possible to replace electrolytic caps with polymer caps on a Slot-1 motherboard. Just an example from Vogons:
[build log] My attempt at building the "ultimate" 440BX
machine
Polys are better than lytics (lower ESR, higher ripple current, higher reliability & longevity), if more expensive.
That's why all motherboard makers switched from lytics to polys around ~2007.
A blast from the past 😀 : Gigabyte Adopts Solid Polymer Capacitors For Motherboards
Let the air flow!
Reply 11 of 17, by Takino-42
TELVM wrote on 2026-06-07, 21:21:
Provided the rest of the hardware can manage 133MHz FSB stably ... fresh, healthy, in spec caps will enhance stability. […]
machine
oh yup I messed up between SMDs (they can be electrolyte too) and polymers since they have the same capacitor "shells". Thanks both for yall advice.
Reply 12 of 17, by Takino-42
And to put the final nail in the coffin for this thread, again... what are ratings for those lil caps? Took this image from retroweb (the image should be unlicensed since it was left unmarked), marked 3 various cap sizes with different colors (red - smallest, yellow - biggest). And should I really change em???
Reply 13 of 17, by bloodem
I’ve also encountered some (minor) FSB133 related issues with all my 6163 ver. 2 boards, when using certain video cards (though, most video cards still work without any issues). I should mention that those same video cards that exhibit issues on these motherboards work just fine on other 440BX boards at FSB 133 / 89MHz AGP.
However, the two 6163 ver 1.0 boards I have, do work at FSB133 just fine with any of the AGP cards I tested (in fact, I use one of those boards in a fully built PC from 2020, and it’s been rock solid).
I wonder what your experience has been and what issues you ran into @ FSB133.
Takino-42 wrote on 2026-06-15, 06:35:
I recapped my boards some years ago, and IIRC, those are 100uF / 16V caps. My boards are in storage now, so maybe someone else can confirm that this is indeed the case.
As for replacing them, I personally would (just for consistency), but it’s very likely that the old ones are still OK as well, since those small caps tend to last longer (and were probably not affected by the capacitor plague).
2 x PLCC-68 / 4 x PGA132 / 5 x Skt 3 / 1 x Skt 4 / 9 x Skt 7 / 12 x SS7 / 1 x Skt 8 / 21 x Slot 1 / 8 x Slot A
Current PC: Ryzen 7 9800X3D
Backup: Ryzen 7 5800X3D
Reply 14 of 17, by PcBytes
bloodem wrote on 2026-06-30, 20:42:
Would not do 133 FSB properly regardless of GPU used - Kyro, nVidia, ATI, 3dfx, didn't matter. All would lock up within minutes. Same 133FSB CPUs would work fine on other boards like BE6-II and P3B-F.
Reply 15 of 17, by bloodem
PcBytes wrote on 2026-07-01, 05:59:
Ah, OK. My experience is different with the boards I have. There are no lockups, only weird artifacts with certain cards.
Like, for example, when using a certain Asus GeForce 2 Ti model (which works fine on all other boards), I had dark bands/artifacts in 3DMark2000 town ("Adventure") test, while another Asus GeForce 2 Ti (different / newer model) worked fine.
Reply 16 of 17, by Takino-42
Anyway I did got to finally test that board, it did 133mhz fsb just fine (atleast when I got into bios and booted tiny core linux since I kinda lack IDE HDDs now), unfortunately I kind of have broke the pin on the bios chip and had to get the BX master board. The latter does 133mhz fine too I guess, but gotta wait till I get the HDD... Since this thread is still going, I'll also write if I get any instabilities later. The GPU I have used is GF4 MX440
Reply 17 of 17, by Takino-42
Takino-42 wrote on 2026-07-03, 01:49:
Well, it works. Quake 2 and 3 work good, however the Promise Ultra 66 controller be tweaking so have to use the regular DMA 33 (might be my IDE-SSD adapater tweaking with external controller? Idk). Also, bad PSUs can mess your drives up and their detection btw, had to swap one PSU today... Tested it all on Windows 2000
