First post, by KIng Mustard
- Newbie
I recently bought a PC containing an Intel Pentium MMX 166 overclocked to 225 MHz. I am wishing to upgrade this CPU.
There are no markings on the motherboard (that I can see) but it is likely a Matsonic MS6260 or Jetway J-542B/C(S) motherboard that I have.
It has the ALi Aladdin V M1542 chipset with M1543C Southbridge. The BIOS is v4.51PG V.542C/542CS D06 (25 Oct 2000).
I believe my best options are AMD K6-2 and AMD K6-III CPUs.
Assuming this is the case, having done a brief look on eBay, it appears my options based on current listings would be:
AMD K6-2 300 MHz (£14)
AMD K6-2 350 MHz (£13)
AMD K6-2 400 MHz (£15)
AMD K6-2 450 MHz (£25)
AMD K6-2 475 MHz (£48)
AMD K6-2 500 MHz (£22)
AMD K6-2 533 MHz (£35)
AMD K6-2 550 MHz (£90)
There were currently no reasonably-priced AMD K6-III CPUs on there.
That AMD K6-2 550 MHz CPU is a bit too expensive, in my opinion (£90).
Would you say that AMD K6-2 533 MHz (£35) is a good purchase/middleground?
Is eBay even my best place to look?
