First post, by matze79
7050 / 5032 / 3225 SMD Oscillator to DIP-14 Adapter
GitHub:
https://github.com/matze79/DIP14-OSC-Adapter
I designed a small adapter PCB that allows common SMD crystal oscillators (packages 7050, 5032, and 3225) to be used as a DIP-14 oscillator replacement in vintage and retro hardware.
DIP-14 oscillators are becoming harder to source and more expensive, while SMD oscillators are cheap, accurate, and widely available. This adapter makes it possible to keep older boards running without modifying the original hardware.
The attachment osc2.jpg is no longer available
The attachment osc1.jpg is no longer available
Maybe some one needs this too.
KiCad Files are on Github.
Errata:
- forgot pin 1 mark
Reply 1 of 1, by maxtherabbit
neat
