First post, by TheMysteriousGray
Hi,
I was wondering if the Voodoo3 had the ability to natively stretch screen resolutions in some way? I have mine hooked up to another PC to capture video from the S-Video port and it generally works quite well, except that 320x200 games like Doom are not aspect-correct in the capture window. This isn't a big deal when just using the old PC by itself, because I have a monitor that can adjust the picture to the correct dimensions, but streaming that video to another PC results in a somewhat squashed display in lower-resolution modes. Regular aspect ratios like 640x480 or 800x600 are fine.
Is there anything I can do to correct for this with just an S-Video capture device and the two PCs on hand, or will I need to buy/finagle a new solution that properly captures the source footage?
