First post, by ripsaw8080
Rank DOSBox Author
DOSBox Author
I recently read a note on the MT-32 compatibility list that Simon the Sorcerer can sometimes play its Roland music incorrectly when switching songs because default instruments and/or controllers are assumed in some cases, and that ScummVM works around the issue. Also, though the compatibility list doesn't mention it, comments in the ScummVM source code state that WaxWorks is similarly affected.
A solution for retro DOS PCs (and DOSBox) seems simple in concept: when the game loads music data, send an "All Parameters Reset" SYSEX command and then delay for a few timer ticks to give the synth some time to process the command before proceeding.
The attached workaround program is what I came up with, which includes support for WaxWorks -- simply extract it into the game directory and start with SIMON.BAT or WAX.BAT as usual. I've only tested with DOSBox and MUNT, but I hope it works on real systems as well.
The attachment simonrol.zip is no longer available
While analyzing the Simon code, I learned that the floppy version has the ability to play sound effects on the Roland synth similar to what it does on Adlib. However, it is not a configurable option, so I made an alternate version of the workaround program that additionally modifies the game in memory to play the sfx. The alternate is in the ENABLEFX subdir in the archive attachment, and of course it will only work with the floppy version of Simon (the CD-ROM version has digital sfx).
The Roland sfx are instrument patches (panned hard left for some reason) or percussion sounds, and I think the game developer didn't make them an option because they work better in some cases than in others. It might be possible to play Adlib sfx with Roland music, as ScummVM can, but it does not appear to be a simple matter as it was with enabling Roland sfx with Roland music because the game code was not originally designed to initialize and drive more than one sound device.
Update: Improved workaround program to avoid potential problem.
Reply 1 of 4, by keropi
oho! another quality patch, thanks ripsaw8080!
I have only played simon in the 90s when it was released with sb support and just a few times to test mpus so I am not familiar with that bug since I did not spend more than 5mins on the game
but the sfx option is interesting - is there some place near the start of the game that we can hear some roland sfx?
🎵 🎧 SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
Reply 2 of 4, by ripsaw8080
Rank DOSBox Author
DOSBox Author
keropi wrote on 2025-12-22, 16:48:
Indeed, there is a good amount of it in the intro/credits at the beginning.
BTW, the game files appear to label the sfx as "stings", and AFAICT there is 1:1 parity between Adlib and Roland interpretations of the sounds.
Reply 3 of 4, by carlostex
Another amazing patching effort! Gonna try this now!!
Reply 4 of 4, by DustyShinigami
Awesome. Should be getting my first MT-32 soon and checking through the compatibility list led me here. Thanks for this! Will give it a try with my DOS version. 😀
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
