First post, by wbahnassi
- Oldbie
Hi, I typically help people with getting their 5.25" drives to work, but it seems this time it's my turn to ask for help..
I have this lovely, almost brand-new, YE-Data 1.2MB drive that just gives "Error not ready reading".
I noticed that putting a disk in it causes the spindle motor to activate but it never stops. Moreover, the speed at which it goes at is way too fast!
Luckily, I have another YE-Data drive of the same kind that has the exact same electronics, except for the spindle motor board and motor itself. So what I did was swap boards between the two drives and I was able to confirm that they are all good except for the spindle motor board on the defective drive. It makes the same bad behavior even if I connect it in place of the good drive's spindle motor board. Unfortunately as I said, the other good drive has a different motor board (Sanyo) so I can't compare 1:1 with the defective one on a component level.
So the focus is this misbehaving spindle motor board. It's a very simple one-sided board with just one IC and a few components.
The IC is covered by a big copper heatsink, and indeed it goes quite hot during operation.. probably hotter than what it should be if it's driving the motor faster than 360RPM.
One interesting observation is that while the drive is spinning the disk, if I touch the right electrolytic cap, then the motor slows down noticeably. It still spins faster than 360RPM I think, but maybe it goes down from 600 to 450RPM. Touching the left electrolytic cap doesn't cause any changes. We're talking just a gentle touch here, no pressure at all.
I did check for shorts and nothing obvious stood out. Resistance across one of the caps was in mega ohms range, whereas the other one was in around 30K ohms range.. I wonder if this is ok. I don't feel any warmth when touching those caps nor any other components for that matter (except the IC).
All resistors measure to their face value, and the inductor is good. Input voltages are 5+ and 12+ and they are coming fine into the board.
Any suggestions on where to go from here? Could those electrolytic caps cause such weird behavior? I'm not a fan of recapping blindly, especially those surface-mount electrolytics. I don't have hot tweezers to extract them easily, and I don't want to subject them to hot air and lose an eye in the process 😅
Turbo XT 12MHz, 8-bit VGA, Dual 360K drives
Intel 386 DX-33, Speedstar 24X, SB 1.5, 1x CD
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, Voodoo3, RTX2080Ti
