Virtua Fighter 2
First post, by Johnylyr
Hello everyone and merry Christmas!
I own a physical copy of virtua figter 2 and I managed to install it and play with the D3d patch but there is one problem that I have never seen anyone mentioning. The VF2 window's title bar and menu bar are always visible and as a result, you can never see the players' health bars.
Can someone help me solve this? I have already tried several compatibility options combinations but no luck so far.
attachment%5D
Reply 1 of 3, by BEEN_Nath_58
One method would be to install Microsoft ACT and apply the ForceSimpleWindow shim. Alternatively, just put DDrawCompat or dgVoodoo2 in the game folder.
Reply 2 of 3, by Johnylyr
Thank you very much for your reply. I already tried dgvoodoo and it crashes to desktop in all the configuration settings I tried. I will search how to try your 2 other suggestions.
Reply 3 of 3, by Johnylyr
DDrawCompat did the trick. I just downloaded it and placed it inside the VF2 folder and it worked correctly right away. No configuration at all needed. Thanx again!
