First post, by AberTim
Hi People,
Out of idle curiosity, I bought three used i5-3570k CPUs from eBay.
When they turned up, 1 didn't work and the other 2 did, and idled in Bios settings at the
normal 3.40Ghz OK, but consumed about an extra 8-12 percent in wattage and
the average temp compared to the plain i5-3570 was also 8-10 degrees higher.
It is my "assumption" that the 'k' CPUs have all been damaged by Overclocking.
My question is, does anyone "know for sure" if the 'k' versions (when new) did have the same low
power consumption as the plain i5-3570?
Reply 1 of 6, by Karbist
These cpus suffer from crappy thermal paste Intel has used in them, they must be delidded.
Reply 2 of 6, by ott
AberTim wrote on Today, 11:16:
Yes, that's possible. I was overclocking the 3770K ES and trying to get it stable at 4.6-4.7 GHz, but it seems I overdid the core voltage.
After that, it won't overclock above 4.3 GHz.
Reply 3 of 6, by The Serpent Rider
Desktop Ivy-Bridge has a regular paste under IHS instead of solder. These CPUs are almost 14 years old.
Reply 4 of 6, by AberTim
Thanks guys,
I did get the impression that the temperature of the spreader lid wasn't consistent with the temperature of the core, but also thought the die to spreader connection was of the "hard" glue bond. Now I know different, I've ordered a de-lidder from AliExpress. ("delidders" who'd have guessed?)
Also something I didn't mention about the CPU's, was that all three had patches of discolouration on the underside, which although did buff off with an oily rag, they very much struck me as heat generated and were around groups of 4 pads. My guess is that the motherboard current sense circuitry may well have saved the CPUs from complete destruction. due to thermal runaway. I must have around a 100 CPUs, but have never seen this discolouration before. That said I've not "knowingly" had such an easily over-clocked type either!
The last actual over-clocking I did was a 80386 DX-33 around 1991. I killed it, and it cost me about 2 weeks wages, and I sort of lost interest in it after that.
Reply 5 of 6, by The Serpent Rider
Pretty sure 386 can't be killed by any common kind of overclocking. There's no voltage adjustments and it's feeding directly from +5V line from PSU.
Modern CPUs? Yeah, those are very easy to kill, they already run on the edge of possible from the factory (cough cough 14900K).
Ivy Bridge is somewhere in the middle, but statistically it's very uncommon to encounter a degraded from overclocking CPU, not a lot of people bother with that, especially on midrange stuff.
Reply 6 of 6, by shevalier
I am not prepared to confirm this from personal experience, as I am not involved in ‘high-performance sport’.
However, it is traditionally believed that CPUs with "high leakage currents" (i.e. with higher consumption at idle) achieve more highest frequencies in extreme overclocking.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
