First post, by iiamsiincere
Hello
Any suggestions for a 4:3 LCD monitor with low response time and maybe a high refresh rate?
I plan to use this for either shmup emulation and pre-Windows 7 PC games.
I know most LCDs don't have great color accuracy but maybe there's a model worth taking a look at.
Reply 1 of 4, by The Serpent Rider
Average run of the mill CRTs also had pretty shitty color accuracy. So it's not a tradeoff.
You can forget about the high refresh part. But there are some new 1600x1200 panels made for arcade cabinets and retro consoles with a bunch of neat features like scanlines. Not cheap though and supply is low.
Reply 2 of 4, by iiamsiincere
The Serpent Rider wrote on 2025-12-27, 01:13:
Average run of the mill CRTs also had pretty shitty color accuracy. So it's not a tradeoff. […]
Yea, way too much money. Hence me trying to find older models.
Reply 3 of 4, by rmay635703
iiamsiincere wrote on 2025-12-27, 01:20:
Samsung had older syncmaster 4:3 LCDs that were actually multisync.
Depending on the model some had fair response rates, not up to modern standards but usually better than most period correct screens.
There were “exotic “ special built LCDs made back in the day that had good response times but I would expect them being hard to find.
Reply 4 of 4, by nd22
I still have 2 working Samsung 940bf - 19 inches, 1280*1024@75 - response time is 2ms. I did played NFS on them and I did not see any ghosting. Color accuracy is pretty low though!
