First post, by vtech
Hello,
Had this nice SB16, it worked fine for 10 minutes then the MIDI sound is gone, if I cracked the volume I can hear something, but with very low quality, everything else works fine. From a preliminary diagnostics I found 3 shorted capacitors (C178, C179 and C180) but I need help to identify the possible values, in therms of physical size they are identical.
Much appreciated if someone can tell me the right values or what should be from experience.
