First post, by DustyShinigami
- Oldbie
It looks as though I'm going to need to replace my 80GB HDD, that I use for storing game images, as it's almost out of space. I have the Windows update installed that allows FDISK to recognise bigger HDDs, but I've read it's still limited to around 128GB. I'm thinking of getting a 256GB drive, which should be a sweet spot. However, because 98 only supports 28-bit LBA, it technically doesn't support higher than 128...? I briefly saw mention of needing some special LBA drivers to increase it further...? Could someone explain, or point me in the right direction, on what I need to do exactly? I can't imagine it's a simple case of downloading a driver and hey-presto - problem solved.
Or, is it not recommended to do this? Are people more in favour of just partitioning a big drive?
Thanks
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
