First post, by AlessandroB
I have a P4 system with two hard drives. I had Windows 98 installed on the first, and then I made the mistake (because I haven't done it in a while and didn't remember) of installing Windows XP on the second hard drive. However, instead of doing two clean installs, it did a dual boot on C: and placed the WinXP files on the second drive. I then reinstalled WinXP on the second drive, connecting it alone, so the two systems are separate and each is on its own drive. However, the dual boot remains on C:. How do I remove it and restore the original drive to its original state with only Win98 installed? That is, without any files added by WinXP and without that annoying duel boot? I'm a fan of precise things and would like to eliminate every trace of the mess I made by installing WinXP. Thanks.
