First post, by przemek
I have Toshiba Tecra 750 DVD with batteries leakage. The laptop has been stored probably in some kind of basement, it smelled so. Before I opened it I tried to start it and it has started. It started to bios. So far so good. I couldn't test more, because it has no hdd. The bad thing is, probably due to wet basement it has battery leakage. I thought only to the laptop case, but some parts of motherboard have been also touched with acid. I have cleaned it with vinegar then water and then IPA. Can I do more? It does not look the best, I also do not know if it start after cleaning. Some places look "black" so some kind of corrosion has started. Will it stop after this cleaning ? What is your experience, could you evaluate the damage ? I have other cdts (Tecras, Satellites, Pros) but this model is one of the best so far I know so I want to keep it and try to repair it. I will clean the case and probably reassemble it. Pictures of the affected place attached. Thanks in advance.
