First post, by DustyShinigami
- l33t
So I've been finishing up the tweaking of a couple of Build games, and I got BMOUSE working with Duke Nukem 3D via a custom BAT file, however it doesn't appear to work with Blood. I can get the utility to load either without a game linked to it or via the Setup, but adding BMOUSE.EXE LAUNCH BLOOD.EXE seems to fail. Works perfectly fine with Duke though. I appear to get a command error, so I'm not sure if Blood requires a different version of BMOUSE...?
I get:
src\blood.cpp(1551): Invalid argument: -control.
Also, I've tried NOLFB with Duke3D and Blood to try and eliminate the flickering I get. However, now I get screen tearing. I did come across this thread - NOLFBLIM (updated NOLFB) - Enables VSYNC for DOS Games - but NOLFBLIM doesn't appear to fix it. I even tried both NOLFB and NOLFBLIM together. I get the same problem in Blood, too.
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
