First post, by clau7723inventor
Hi everyone!
I’ve always wanted to keep my retro machines connected the "authentic" way, so I’ve finally set up a dedicated 24/7 Dial-Up server from Arica, Chile, and I’d love for the community to help me test its stability.
The Server Setup:
OS: Windows 2000 Professional (using Routing and Remote Access / Incoming Connections).
Hardware: Desktop PC with a 56k V.92 internal modem.
The Bridge: I'm using a Linksys PAP2T ATA bridged via VoIPbuster and Flynumber.
Optimization: Configured with G.711u codec and locked at V.34 (33.6kbps) to ensure handshake stability over VoIP jitter.
How to connect: If you have a modem-equipped PC (MS-DOS, Win9x, etc.) and want to give it a try, here are the details:
Phone Number: +1 (315) 946-8115 (Syracuse, NY node).
Username: invitado
Password: retro2024
Settings: 8N1, No Flow Control (or Hardware), and remember to disable "Wait for dial tone" (ATX4) since the ATA tone might differ from a standard landline. (not necessary for now)
The server is set to answer on the 1st ring for a snappy connection. I’ve tested it with a few machines and it’s working surprisingly well for browsing the "Old Web" (TheOldNet, FrogFind, etc.).
I'm curious to see how different modems handle the handshake through the VoIP bridge. If you manage to get online, please post your hardware specs and where you're calling from!
Happy 56k surfing!
Reply 1 of 2, by clau7723inventor
Wow, thanks for the interest guys! The server is up and running 24/7 on Windows 2000. I've optimized the PAP2T settings for a faster handshake. Looking forward to seeing the first connection logs!
Reply 2 of 2, by clau7723inventor
Quick Update on Credentials!
Just a small heads-up for those trying to dial in: I noticed a case-sensitivity issue with the server's login. Please make sure to use a capital "'" for the
username.
• Username: Invitado (Case sensitive!)
• Password: retro2024
The server is currently running on my ThinkPad
X61s for the night shift (dead silent!) and will be back on the Windows 2000 Desktop tower later
today.
If you get a "Checking Username and Password" hang, double-check that capital I. Happy dialing!
