First post, by lesliespinner
Hi guys, I've searched in many places, but with no luck, so if anyone recognise it, please speak out. On the back side, more in the middle, there is a logo imprinted with PCB, but I can't tell which vendor it is. The card is not working, but I've tested the bios chip on w32ax model and it worked. The card has a lot of jumpers, so I actually would need some documentation to get it to work.
Reply 1 of 9, by PC Hoarder Patrol
lesliespinner wrote on 2026-01-11, 10:14:
Best guess at the moment would be BCM ADVANCED RESEARCH, possibly the GP4000 ( https://theretroweb.com/expansioncards/s/unknown-gp4000 ), given the matching images, that this cards name seems to follow the naming convention of other listed BCM expansion cards and that the cards MTL jumper manual lists JP12 specifically as configuring the card for use on either BCM or non-BCM motherboards.
Reply 2 of 9, by lesliespinner
This is it! Thank you so much! Just an hour ago, I went for another spin, ended up in the Cardex deadend...
Reply 3 of 9, by lesliespinner
It works! It was left jumped on 2mb, while they probably took out extensions, and it shined after I've jumped it to 2WS. Thank you again, it really made my day 😀!
Reply 4 of 9, by TheMobRules
Got one of those cards recently, the BIOS mentions "ColorView" at the very end, so that may be the actual manufacturer.
When jumpered to 1WS (JP8 and JP9 on 2-3 position) it's even faster, and upgrading the memory to 2MB will enable memory interleaving, massively increasing performance on Windows.
Reply 5 of 9, by lesliespinner
Awesome! Thanks for the info! It didn' want to work on 1ws on this mobo, but I'm planning this card for another build anyway. Have to find ram chips though...
Reply 6 of 9, by thisisamigaspeaking
How specific are the memory chips on these? This is a 256K x 16 FPM SOJ-40 socket? 70ns? Some material refers to the chips that go here as 512K x 8 instead of 256K x 16. Thanks.
Reply 7 of 9, by mkarcher
thisisamigaspeaking wrote on 2026-03-13, 04:04:
There are two kinds of x16 FPM chips: Dual /CAS and dual /WE. I don't know which variant the ET4000/W32i requires, but the way you can read/write single bytes works different on them. Check the data sheet of the chips already present. I wouldn't assume 512K x 8 to be available in SOJ-40 at all, but if it is, it won't work on this card. The W32 requires 32 bit wide memory, and as there are only two sockets, you clearly need x16 memory. Avoid overly fast memory (like 25ns), because IIRC the memory interleaving relies on a positive data hold time after /CAS has been deasserted which isn't big enough on those chips. As 25ns chips are most likely EDO, they wouldn't match the FPM requirement anyway.
Reply 8 of 9, by thisisamigaspeaking
mkarcher wrote on 2026-03-13, 07:30:
I went ahead and ordered what are hopefully the exact chips already on the board.
Reply 9 of 9, by thisisamigaspeaking
I think I've seen that some of these W32 boards have 45ns RAM. Which I'm not sure I've seen for sale today, certainly 40ns in more modern chips though. Will it run at its lowest wait states with 70ns? Might be a fun project board to replace all the RAM.
