First post, by _StIwY_
UPDATE: Solved by resetting the BIOS and leaving everything at default ( except enabling PnP OS option, disabling the integrated sound card and the ethernet adapter ). I usually disable the Parallel / Serial / ACPI / Power functions when possible, to minimize IRQ conflicts or problems, but this time things went the other way xD
Really don't have the patience to test the BIOS and find out what it was
Hello i have an IBM motherboard equipped with Intel 810E2 chipset. The problem is simple, yet unknown. The hardware seems fine:
1) No bulging capacitors
2) Running Prime95 overnight ( 12+ hours ) show no problems
3) Running Memtest overnight ( 12+ hours ) shows no problems
4) Deep diagnostic at the Hdd shows no problems. And even changing it shows no differences.
4) The motherboard has been flashed with the latest BIOS
5) There are NO external cards, no video card, no audio card connected, nothing.just the motherboard, the onboard video and the RAM.
6) Tried different PSUs, no difference
Everything seems fine, except...after the first reboot after i try to install Intel chipset drivers. the PC goes to a blue screen of death ( bsod ) when trying to install this "Intel 82802 HUB Firmware Hub device". I scratching my head...i really don't know what to do, any ideas ? Thanks.
Video:
https://drive.google.com/file/d/1QTTBs9sNnyyW … iew?usp=sharing
