First post, by Danger Manfred
Hi, I thought there must be someone here who has the card working on Windows 98 SE.
My problem is as follows: the card installs fine under Windows 98 SE (W98 Quickinstall, current version), but then I'm prompted to reboot, and after rebooting, the second I'd see my Windows desktop, the display says signal out of bounds, and I have to hard power off the system.
If the card is removed OR if the driver is uninstalled in Safe Mode, everything works again.
Also I discovered that if you do not reboot the system, the card actually works until then. Which was okay for what I wanted to do (make recordings of the card's FM synthesizer and wavetable), but the card is not working in full duplex mode per default, meaning I can only record one of two channels! Two switch it into full duplex mode, you have to change the configuration of it in the device manager, which is then only applied upon reboot, but as I already said every reboot breaks the system.
I tried this in three different systems and with a Windows 98 SE Quickinstall version but also the official US installation, so I'm pretty sure that the problem is the actual driver I am using.
I don't remember where I got it from, but not the official Terratec website, which only offers a Terratec Maestro 16/96 driver, not a 16/95.
Has anyone got a driver that is confirmed to actually work?
