MX440SE from ebay
First post, by Devil996
I got an MX440SE, but I couldn't install it under Win 98. As soon as I loaded the drivers, the system wouldn't boot. So I tried Win XP and I was able to install the drivers, but 3D Mark (99-00-01) wouldn't launch, and the worst thing is that Direct X tests (ddraw and d3d) wouldn't launch either... Nothing 3D-related would launch...
I think it's done for, right?
Reply 1 of 8, by douglar
Sounds like it, but you can try cleaning the edge connector or putting a fan on it,.
If that doesn’t work, check for bulging or hot capacitors.
Can you post a picture of the card?
Reply 2 of 8, by Devil996
Everything seems fine, even the capacitors. I ran some tests on the vram using Ultimate Boot CD, and it completed them. It's not showing any artifacts, but it's as if half the chip is off. As a last resort, I might try warming it up with air.
Reply 3 of 8, by RetroPCCupboard
Hmm, there should be a cooler of some sort on that. Even if passive. If it's been run without, it may have got too hot and got damaged.
Reply 4 of 8, by Devil996
RetroPCCupboard wrote on 2026-01-16, 10:28:
It has its own working fan. I removed it to take photos and clean.
Reply 5 of 8, by red-ray
My MX440-SE has a fan, how hot does the chip feel?
When running on XP how do all the clock speeds compare to my clock speeds, I used my SIV utility to report them, do Menu->Machine->GPU Information to get the panel.
file.php?id=234554
I guess it's too old a card for NVCPL to report the temperature.
Reply 6 of 8, by havli
This seems to be SDRAM based MX440, definitely uncommon card. 😀 One of the slowest GF4 MX, granted, but interesting still.
Trying it in different PC also might help.
Reply 7 of 8, by douglar
havli wrote on 2026-01-16, 18:47:
True, sometimes those AGP 4x cards prefer to be in an AGP Universal slot and can be touchy in an older or newer AGP slot. A motherboard with an i815 chipset is probably the most compatible.
Reply 8 of 8, by Devil996
Unfortunately, if it doesn't work, it loses a lot of its appeal. Maybe I'll warm it up later...
