First post, by ripsaw8080
Rank DOSBox Author
DOSBox Author
The new AGI video drivers are coded by myself, and installation is easy: make sure you have a backup of the original CGA_GRAF.OVL file and then extract a replacement from either of the attached archives.
The attachment 1512_AGI.ZIP is no longer available
The attachment PLAN_AGI.ZIP is no longer available
The drawing routines are optimized for speed, but I estimate that an 8 MHz 8086-class CPU is the minimum needed because the 16-color video modes are somewhat complicated. Upgrading the PC1512 to an NEC V20 or V30 may help a bit.
Original driver files usually only work with the version of the AGI interpreter they were released with because they are actually overlay files that use specific addresses. However, my new drivers are "universal", adapting themselves to the interpreter. AFAIK, all released DOS interpreter versions are supported, from v2.089 in Space Quest 1.0X to v3.002.149 in Gold Rush and the Manhunter series.
Both drivers have been tested in PCem but so far not on hardware. I've not been able to see how well the horizontal display positioning (Ctrl+Alt+Left/Right) and screen shaking work in the Plantronics driver, although it should be the same as the original CGA driver, but if necessary I can switch to the screen shaking method used for PC1512 (which has no display position feature because its VDU does not fully emulate a CRTC). So, there may be revisions if issues are found.
Update: Plantronics driver fixed for blinking text with certain brands of BIOS.
Update: Amstrad driver workaround for display border flash when setting text mode with V1 BIOS.
Reply 1 of 47, by zyga64
This is very good news! In addition to PlanetX3 and Petscii Robots, we now have Sierra Games with SCI0 from Benedikt and Sierra Games AGI from you! I'll test it today on my 8MHz Turbo XT + Genoa Spectrum CGA (Plantronics compatible).
Thank you and congratulations !
8088@8 /640k /TVGA9000C /ALS100+TNDY 3voice
286@20 /4M /CL-GD5422 /CMI8330
486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
K6-2@400 /64M /MGA-2064W+3dfx /YMF718
P!!!750 /256M /MX440 /Vibra16s+SBLive!
Reply 2 of 47, by rasteri
Awesome! I have a PC1640 and an ISA Paradise Pega1A I'm looking forward to testing this on.
Reply 3 of 47, by zyga64
It works great on real hardware (Plantronics capable CGA) !
Reply 4 of 47, by ripsaw8080
Rank DOSBox Author
DOSBox Author
In SQ1 (brown status bar) and KQ3 (residual command in blue) there is the suggestion that something isn't working as intended on the blue/intensity bank in all cases -- perhaps some unexpected behavior of the system BIOS. I'll check if it needs to be more resilient.
BTW, how do the help and inventory screens look on your system? Inventory should have an intense white background and no blinking characters.
Reply 5 of 47, by keropi
this is a thread designed to make me feel guilty 🤣
excellent work as always ripsaw8080 , one day I will be able to add some 1512 shots here!
Reply 6 of 47, by BitWrangler
Awesome!!! Thanks very much for this.
Kinda regretting leaving Amstrads behind in the 90s now, even though I got them as ugly broken scrap, and only got them as far as working ugly obsolescent doorstops at the time. I am real tempted every time a portable turns up, only one they seem to have sold many of in Canada, or the only one that migrated with Europeans.
I will have to find a card that does plantronics though to play with this, got an inkling that one exists somewhere within 50ft of me, but not sure which/where exactly.
Reply 7 of 47, by zyga64
ripsaw8080 wrote on 2026-01-16, 17:33:
Your prediction was correct! I checked with the Phoenix ROM 2.27 BIOS that was originally on this motherboard (the pictures were taken with GlaBIOS 0.4.1) and the status bar is now white all the time (previously it sometimes turned brown) and the residual command characters are now white (previously it sometimes turned blue).
Inventory is like you said - white background and no blinking characters (also with GLaBIOS)
Help screen is: black background with white text (or maybe it is light gray because the contrast is not so strong ?) also nothing is blinking (doesn't matter if Phoenix or GLaBIOS).
Reply 8 of 47, by ripsaw8080
Rank DOSBox Author
DOSBox Author
zyga64 wrote on 2026-01-16, 18:50:
Thanks for testing. GlaBIOS may be altering register values that it should not when returning from the scroll window function. However, to clarify, there should be no residual command characters of any color. Typed commands should be cleared away after pressing enter, leaving only an input prompt.
Reply 9 of 47, by zyga64
You are right. I described it incorrectly (-‸ლ). The behavior is as follows:
GLaBIOS:
When I type the first command, it's white. After pressing Enter, the text color changes to blue.
When I type the next command, it remains blue (overwriting the previous one).
Phoenix BIOS:
The letters are white all the time and after pressing Enter text disappears.
I can also check with Turbo XT BIOS 3.1 and Sergey Kiselev's BIOS
Reply 10 of 47, by Kekkula
Awesome!!!
Thanks, works great on my Commodore Pc10-III.
... Now if I just could get picogus to play tandy sounds 😭​
Reply 11 of 47, by Benedikt
Kekkula wrote on 2026-01-16, 20:32:
Awesome!!!
By the way...
You are among the very few owners of the elusive GO 329 expansion card for the Olivetti M24, right?
That card's 640x200 pixel 16-color mode has largely the same frame buffer layout as the Amstrad PC1512 VDU in its 640x200 pixel 16-color mode.
The only major difference is that the PC1512's VDU only has one 16 KiB window in the system's address space, through which the four 16 KiB bit planes are accessed, whereas the M24 with GO 329 keeps all four bit planes accessible through one 64 KiB block one 128 KiB block of 32 KiB bit planes large enough for the 640x400 pixel 16-color mode (I previously misremembered that).
That all in all rather minor difference means that an AGI driver for the GO329 is well within reach! 😀
zyga64 wrote on 2026-01-16, 07:09:
The Plantronics ColorPlus code paths in Planet X3 and Attack of the PETSCII Robots are mine, too. 🤣
Reply 12 of 47, by zyga64
Benedikt wrote on 2026-01-16, 21:45:
Of course I knew it 😀 You are a pioneer in this field! Hats off to you!
Reply 13 of 47, by Kekkula
Sorry for the off topic, but I'll try to find time this weekend to setup the m24.
It's bit of a hassle since I don't have original monitor nor keyboard...
Reply 14 of 47, by zyga64
...continuation of tests
with Turbo XT Bios 3.1 https://www.phatcode.net/downloads.php?id=101
- inventory text is blinking !
- rest is normal - no unusual colors in top bar, nor residual characters
with Sergey Kiselev's 8088_bios (v1.01) https://github.com/skiselev/8088_bios
- everything is normal (except for slow scrolling in text mode, i.e. dir., compared to other BIOSes, but games are ok)
Reply 15 of 47, by ripsaw8080
Rank DOSBox Author
DOSBox Author
zyga64 wrote on 2026-01-17, 13:35:
Can you check to see if that's any different with the original CGA driver? After setting text mode, my drivers disable blinking characters not with BIOS but with hardware (clearing bit 5 of port 3D8h). This suggests that some character output function of the BIOS you're testing is re-enabling blinking characters, which would be incompatible behavior.
Reply 16 of 47, by zyga64
In normal CGA mode (which is very ugly BTW) inventory text is not blinking. Only in Plantronics mode (with this Turbo XT 3.1 BIOS) !
BTW. I checked screen shaking according to this video: https://www.youtube.com/watch?v=Xz1OrHzQIlw
It works ! 😀
Reply 17 of 47, by Kekkula
Olivetti m24 with plantronics files.
Reply 18 of 47, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Is the Olivetti system in question supposed to be compatible with Plantronics ColorPlus?
Anyway, the Plantronics driver is updated with a fix, see first post for download and notes.
Reply 19 of 47, by Kekkula
Sorry, no olivetti is not compatible with your driver... but comes wery close 😉
But no more off topic from here.
