First post, by GigAHerZ
- Oldbie
Quite a bit ago I wrote about Neo6502: Olimex Neo6502 - Software defined machine!?
It seems like (mostly) it is a real 6502 CPU that has a "virtual"/fake environment created for it by a tiny RPi Pico, making it basically a software-defined computer platform.
... But it is still in hardware.
I'm very... very-very comfortable in software engineering. And it is the very opposite on the hardware side. Hardware issues and debugging has also magnitudes slower round-trip time to try different ideas and fixes.
So, what I figured is that, because I can write code, I could write code that simulates hardware which is defined as pins and connections between them. (I also learn best by building - Once I've built myself a virtual MOS6522 for example, I know very well how to use it.) So I've been playing around with it for 2 days and I think I've gotten somewhere that I kinda like.
On picture is a "platform", that consists of 6502 CPU (i wrapped Asm6502 library into a "Device" compatible for my framework) and 64kB of RAM. (+ pull-up/pull-down resistors provided by the "platform") And it works! But it is somewhat slow: On a Ryzen 7 3700X with Fedora 42 KDE I get platform cycle frequency of ~35kHz. Enough to play around, but nowhere near to do some ~1MHz simulations, unfortunately.
I tried to google and even AI to search for something pre-made. There are SpiceSharp, LogicGraph and SharpCircuit, but they all are way lower-level simulations and therefore quite probably way slower than even my handmade solution. (Those can do analog circuits, too)
Currently I have only a picture to share, showing how the code looks like for such "computer". Any feedback on ideas, concepts and even practical developer experience is very welcomed.
A little about software engineering: https://byteaether.github.io/
