First post, by JayPointSystems
- Newbie
Hey folks,
after the whole “Frankenstein Project” with Windows Neptune had really hooked me, I wanted to see if I could push that success even further back into the past. So, I dove back down the rabbit hole of unreleased Windows versions and ended up with Pre-Alpha Build 1175, codenamed "Cairo".
My idea was to simulate an alternative high‑end setup from late 1995 and find out whether this mythical NT4 predecessor could be convinced to run games. I knew it was an ambitious plan, but I hit the limits of what’s possible much faster than I would’ve liked - but let’s take it step by step.
To recreate the era as authentically as possible, I re‑configured the Super Socket 7 system from my “9‑in‑1” collection:
- The Intel Pentium MMX 233 (SL27S) was downclocked to 2.5 x 66 (166 MHz).
- The RAM was cut in half from 64 to 32 MB.
- The Diamond Monster 3D and ELSA Victory Erazor were replaced with an ATI Mach 64 GX.
Even the installation process was unusual: after prepping the hard drive, all files had to be copied over manually, and setup had to be launched via a bootable DOS Floppy or CD. After about 15 minutes it was done - but the very first login, where explorer.exe crashed instantly, already hinted that this adventure would be tougher than expected.
After several hours of trial and error came the bitter realization: no alternative drivers, no APIs, no mercy. Cairo left me out in the cold and trapped me inside its architectural vacuum. I spent hours slipstreaming, injecting files manually, and trying supposed workarounds, but none of them got me out of this dead end.
So you work with what you have: nothing! But even for the most bare‑bones 2D titles of the era, “nothing” simply isn’t enough. I installed at least a dozen games, and every single one failed with cryptic error messages - until, after many hours, I unexpectedly stumbled upon one exception: Unreal!
The fact that this beast even starts has far less to do with my efforts and far more with the legendary Unreal Engine software renderer - which basically runs on any potato capable of outputting a colored image. But with an average of 5 FPS in VGA and at best 15 FPS in QVGA, it’s hardly what you’d call playable, so I gave up after just a few minutes.
My conclusion: Microsoft Cairo is a curious piece of computing history that never made it beyond its own vision - and it’s so incompatible that it’s basically just a museum showpiece at this point.
And that brings this experiment to an unsatisfying end, which I’ll chalk up as an interesting experience. Sometimes you just have to accept that the limits of what’s possible can’t always be pushed.
